Snap ring pliers
Old Jun 1, 2022 | 08:55 AM
mach5's Avatar
mach5
Stage IV
Default Snap ring pliers
I want to change the passenger footpegs on my 06 Softail Deluxe, but my snap ring pliers are too big. What brand/size pliers can I use to accomplish this??
Old Jun 1, 2022 | 11:06 AM
Spartanden's Avatar
Spartanden
I have a set.... probably 40 years old!! May have gotten them from either Snap-On or Mac Tools. They have interchangeable tips and a couple different sizes. I would suggest going to your local auto parts store, take a drill bit that fits the snap ring, and look for a set that has same size as drill. Best I've got right now!! Good Luck!
Old Jun 1, 2022 | 11:41 AM
mach5's Avatar
mach5
Stage IV
Thx!!!
I will do that!!
Old Jun 1, 2022 | 01:43 PM
LQQK_OUT's Avatar
LQQK_OUT
Lang tools make a real nice kit. Lang tools #3495 12-Pc. Combination Int/Ext Retaining Ring Pliers Set.
Search the Internet for the best price.
https://www.langtools.com/sku-3495-1...ng-pliers-set/
Old Jun 1, 2022 | 07:54 PM
Wapiti Hunter's Avatar
Wapiti Hunter
don't buy the one from Harbor Freight, piece of crap but it does work with a lot of problem.
Old Jun 2, 2022 | 08:55 AM
big cahuna's Avatar
big cahuna
I have a set of snap ring pliers, and I use it every other blue moon. I would ask some of your friends if they have a set you could borrow. Put what you save in the gas tank.,,,
Old Jun 2, 2022 | 11:15 AM
E-clip's Avatar
E-clip
I think you can choose between small (common sized) and heavy duty sized. You need the common sized. For smaller snap rings, any cheap pliers work fine for me (shadetree use). For the bigger rings that would test the limits of the small pliers, I have a pair of Lisle heavy duty pliers that seem decent for the price.
Old Jun 2, 2022 | 12:51 PM
Vec's Avatar
Vec
I just went thru this same thing...
I have 3 sets of snap ring pliers... those holes are teeny tiny... none of my snap-on would fit luckily the set I have from autozone barely worked.
Old Jun 2, 2022 | 01:02 PM
mach5's Avatar
mach5
Stage IV
I think I'm just gonna break the damn things off and install new 1's. They're only a buck or 2 at the dealer.
Old Jun 2, 2022 | 01:09 PM
mskirwin's Avatar
mskirwin
I have a set from Snap on that worked on my ‘02 Softail. I used to use mine for A/C work back in the day.
