S&S cam chest kit
Old Mar 29, 2023 | 02:43 PM
cdremy's Avatar
cdremy
Default S&S cam chest kit
Checked out a local Indy for a quote on a stage 2 from a stage 1 on my 2017 fatboy and was quoted 3000.00. Is this cam chest kit necessary. I thought most people here said around 1500.00 total
Old Mar 29, 2023 | 05:43 PM
nickrat's Avatar
nickrat
A lot of people do the S&S cam chest kit for the upgraded oil pump but it's not necessary. I just did a cam on my 2018 and replaced the pump with the newer OEM version oil pump. I think the pump was around $160 at my local dealer. The new pump doesn't seem to have many issues and is a lot cheaper than the S&S kit.
Old Mar 29, 2023 | 06:24 PM
pgreer's Avatar
pgreer
How much of the $3000 was for labor? Or is that all parts?
Unless you are going bog bore, no need for the cam plate etc. And as nickrat said, the latest OEM pump (upgraded form factory on later 2019 model M8"s) is the least cost option. The main components are the cam, lifters, cam bearing, gaskets and a tuner. If it were mine, I'd also replace the cam chain sprocket on the pinion shaft because they are typically loose on the shaft causing the cam timing to be off by as much as 3 degrees. The fueling sprocket is fairly inexpensive.
Runout on the pinion shaft must be checked while the cam chest is apart. If for some reason you needed a cam plate, I'd likely go with a Screamin Eagle cam plate and oil pump.
To compare, you might check with FuelMoto on prices and recommendations etc.
Paul
JLotano
Aug 29, 2020 12:21 AM
yobtaf103
All Other Models
Nov 6, 2019 01:28 AM
shameless socal
Jul 2, 2012 04:36 PM
g.w.
Exhaust System Topics
Jan 10, 2009 02:00 PM
g.w.
Jan 10, 2009 08:52 AM
