sumping
Old Aug 4, 2023 | 06:01 PM
john lee's Avatar
john lee
Default sumping
how often should a shovelhead be started to avoid sumping
Old Aug 4, 2023 | 06:19 PM
M Oclaf's Avatar
M Oclaf
Daily, through riding…duh!
Old Aug 5, 2023 | 06:13 PM
Since 1968's Avatar
Since 1968
If the check valve in your oil pump is in good condition you should be able to go at least a few weeks. My brother had an '82 and this was his experience. When the bike was going off the road for an extended period like a Canadian winter he would drain the oil.
My '91 EVO had what looked like the same oil pump as his. When the bike was new I could go for several weeks, wish I could remember more exactly but let's say a month. Eventually the ball check deteriorated to where I couldn't go two weeks without puking some oil out. I bought two new ***** and welded one to the tip of a welding rod. I put a very small amount of valve grinding paste on the ball and spun it with the rod to improve the seating somewhat. Then I did my best to wipe out any residual grinding paste and used the other new ball. I could improve it but could never get it as good as new.
Old Aug 6, 2023 | 08:13 AM
bustert's Avatar
bustert
well???
only you can answer that one. i marked the stick and if you do not have one, get one. i started with an empty tank and added one quart and marked the stick and so forth till it was at factory level.
by far, the check ball is probably the last on the list, it is more common through the pump shafts as the machine ages and miles stack on. most hd pumps do not use seals through out the pump, so one side is open to the engine case. there are many so called fixes but one MUST be careful as one may be shooting oneself in the foot. some will take a drift and peen the ball into the seat, bad bad bad, that metal has to go somewhere and the are diff ways the seat is cut, aka, conical and tangent. i have not done this to a BT pump but have done so on the XL.
Old Aug 6, 2023 | 09:02 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The bike will tell you...
Old Sep 8, 2023 | 12:51 PM
Berock's Avatar
Berock
Oops, wrong thread. Sorry.
Old Feb 5, 2025 | 07:30 PM
Russrust's Avatar
Russrust
maybe I got lucky but I changed the ball and spring and I just had a busy 2 months so it wasn't used---started today and didn't need a diaper
maybe you'll get lucky
Zeb Smith
Great Lakes
Jun 25, 2021 03:32 PM
Nugget Shooter
Motorcycles For Sale
Jul 1, 2014 11:38 AM
SportsterBob
Harley Davidson Videos
Dec 10, 2010 07:41 PM
btroy
Shovelhead
Dec 18, 2008 12:18 AM
bhollis
Classic
Sep 19, 2007 12:49 PM
