air shocks
Old Jan 14, 2024 | 07:27 AM
gregjo1948's Avatar
gregjo1948
Default air shocks
2001 Harley Road King with rear air shocks--Did Harley ever install an air compressor to inflate the shocks? thanks, gregjo1948
Old Jan 14, 2024 | 08:32 AM
roussfam's Avatar
roussfam
Nope. Why would you want one? I top mine off in the spring IF they read a bit low, but basically good all season.
Old Jan 14, 2024 | 09:06 AM
Y2K's Avatar
Y2K
They had a small hand pump that works like a bicycle tire pump.
Old Jan 14, 2024 | 09:15 AM
470004's Avatar
470004
I used the HD's touring suspension air pump when I had these rear air shocks.
Old Jan 14, 2024 | 09:18 AM
touchdown's Avatar
touchdown
no hand pump, or better yet replace them with anything.
Old Jan 14, 2024 | 05:16 PM
gregjo1948's Avatar
gregjo1948
Where did they store the pump? I wondered if they ever installed a compressor that would self inflate the shocks.
Old Jan 15, 2024 | 05:43 AM
roussfam's Avatar
roussfam
Definitely Subscribed
Old Jan 15, 2024 | 02:23 PM
Spartanden's Avatar
Spartanden
Don't use air compressor to air up the shocks! They only require 10-30 lbs PSI.... can blow out real quick if not careful. I have the small hand pump to add air. As far as air systems, no idea. Thought I had read somewhere there was a on bike unit for this.
Old Jan 15, 2024 | 02:43 PM
Goose_NC's Avatar
Goose_NC
All the HD air shocks have a very small air bladder. That hissing sound when you remove a regular air chuck will be a loss of 3-4 PSI. The HD hand pump features a no loss attachment that closes the schrader valve before unsealing.
Old Jan 16, 2024 | 08:52 AM
eighteight's Avatar
eighteight
[QUOTE=roussfam;21525471]Nope. Why would you want one?
Well, let`s say your wife is fat and your GF is not..
FWIW, those shocks are shared with Honda G-W which had an onboard compressor
