General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Aren't the bars already reduced to 1" at the bar clamp section?
LA Choppers 1-1/4" Twin Peaks Bagger Handlebars For Harley Touring
Looking to dress up your dresser? LA Choppers presents the Twin Peaks bar designed specifically for bikes with a Batwing fairing to add clearance. They add to touring comfort with a different wrist angle than stock for a more comfortable pullback and less stress on your wrists.
Features:
1 1/4" bar diameter stepped to 1" in riser and control areas
Drilled for optional internal wiring
Works with factory heated grips
Notched for fly-by-wire throttle
Black finish is powdercoated
Made in the USA
Specs:
33.5" width
12" center width
5.25" pullback
Unless the bars reduce diameter along the crossbar, then there's no way to clamp 1.25" bars with the factory risers and clamp(s).
You'll have to replace one - bars or clamps.
