Drag pipe install questions
Old Jun 4, 2024 | 08:33 AM
BobbyTouche7's Avatar
BobbyTouche7
6th Gear
Default Thanks for your input, but…
I appreciate everyone’s insight. But I’ve done my research and I’m aware of the result of drag pipes. I’d just like a little insight into the preferred hardware for mounting the pipes to the crossover. I’d rather not use cheap hardware store nuts and bolts. Is there a particular set of hardware you guys and gals like?
Old Jun 4, 2024 | 08:34 AM
BobbyTouche7
6th Gear
See post # 5
Gracias 😊
Old Jun 4, 2024 | 09:04 AM
Goose_NC's Avatar
Goose_NC
Hardware stores sell grade 5 and grade 8 bolts also. Depending on the store location, some have very good stainless inventory. Unless you want chrome hardware, the local store can supply most.
Old Jun 4, 2024 | 11:21 AM
bustert's Avatar
bustert
what you got is a seat of the pants install, i cannot do it from the key board. i mounted a rubber mount highwayman to a rigid and had to make all the brackets custom, i plugged off the O2 ports with stainless plugs. as far as fasteners go, i like stainless.
BUT be fore warned, when it comes to exhaust and high heat, stainless can gall and thread lock, NOT GOOD. make sure you use a GOOD thread lube, i use desco 220, goes from flame bucket of launch to cold of space. if you burn it it turns to graphite. i learned to use brass for headers since it does not rust, easy to drill out if needed and even if you thread lock it by galling, it will usually still separate but destroyed. a lot easier when forced to use a nut splitter to boot.
Old Jun 4, 2024 | 12:17 PM
Glenn Gorman's Avatar
Glenn Gorman
See post # 5
He has the kit but according to post #5 isn't going to use it. You still need to change the jets even if only scooting around town.
Old Jun 4, 2024 | 03:23 PM
BobbyTouche7
6th Gear
oh, I’ll be using the kit. Sorry I may have worded it weird.
Old Jun 4, 2024 | 09:53 PM
BobbyTouche7
6th Gear
good tips! I did wind up getting stainless, but I’m curious… will a lubricant or anti seize be an issue with the vibrations shaking them loose?
Old Jun 5, 2024 | 07:23 AM
bustert's Avatar
bustert
i never had issue. but if you are worried, go fine thread.
Old Jun 5, 2024 | 07:41 AM
eighteight's Avatar
eighteight
Anti seize and lock washers please
Old Jun 5, 2024 | 01:45 PM
bustert's Avatar
bustert
https://socousa.com/product/chemola-...m-o-plate-220/
split lock washers are just spacers. just like double nutting just takes up thread space.
