Fault Code C1184c
Old Jun 13, 2024 | 10:00 PM
TwiZted Biker's Avatar
TwiZted Biker
Question Fault Code C1184c
Bud's 2021 street glide has been throwing a C1184c fault code since he bought it used a few months back, ABS Invalid VIN From ECM. Anybody have any input as to what to expect ? if he takes it in ? Everything works with the brake system, including the ABS, but won' clear Local dealer wants 2hrs labor to hook it up and reflash the ECM. Trying to get a feel for whats coming and is the labor a bit excessive.
Old Jun 14, 2024 | 07:06 AM
bustert's Avatar
bustert
might have to bite the bullet
apparently the ecu has been swapped out. the abs and ecu needs the same vin or you will get that mismatched code. the abs calibration is locked to a particular machine. nothing new, gm and i would guess most do the same via vin.
a gm dealer MUST input a vin into the system so they can download from the mothership and then to the vehicle, a two step process.
it doesn't hurt the dealer because he got you by the yang-yang!!!
Old Jun 15, 2024 | 03:27 PM
TwiZted Biker
Yeah about what I figured was going on, he picked this up used from a broker sale a few months back. Being Cali and their BS I'm figuring it had a tuner at one point, got flagged, owner did some dancing and sold it to dodge the coming headaches.
rhallman
2014-2024 Touring Models
Mar 1, 2025 09:08 AM
CoolBreeze3646
General Topics/Tech Tips
20
Mar 30, 2023 03:18 PM
Dproff
Jul 12, 2019 09:32 PM
Bufort
Jun 9, 2019 08:29 AM
