Winter Storage
Old Nov 3, 2024 | 03:53 PM
roussfam's Avatar
roussfam
What fuel stabilizer should I use,
Old Nov 3, 2024 | 04:24 PM
Soundman5000's Avatar
Soundman5000
Originally Posted by Sparkules
For the cheep folks like me, instead of a fitted motorcycle cover I got a cheap but breathable / soft car cover, draped and scissored to remove excess. Marked the rear at the top of the backrest “rear” and forward at the top of the windshield “windshield” with a Sharpie since I’m bad at folding then remembering what end went where.
Where I did spend a bit is a 160 watt boat dehumidifier that is slim enough to slide under the frame and is about a 12” sq. box that spreads some gentle heat into the engine and transmission. Also this is in a wooden shed with a wood floor not metal & wood tends to breath a bit not a moisture trap. Engineer at work that did tool & die machining on the side in his garage told me keep condensation at bay by keeping the metal a bit warmer than the outside air.
Battery tender also.
The only indoor cover I will use is the WinPower Indoor Stretch Elastic cover via Amazon $39 and its a snug fit with very thin stretch fabric that keep the dust off but is so thin and breathable you can kinda see through the black cover but keeps my bike clean as I have lots of dust / dirt in my garage. I like this cover so much all my bikes have one, I wash them once a tear and its so thin it looks like it would not last but I started using this cover at least 5 years ago and it looks new.
i always use a battery tender, ethanol free gas with a mix of Sta- bil AND Marvel Mystery oil in my gas, been using that mix 27 years. I used fogging oil a few years but was lots of trouble so I don't do that anymore but my old evo is getting much less time on the road after buying my new bike so I may fog it again this winter?
I have never heard of a160 watt boat dehumidifier, I can see how that would help as if you can get the engine chrome a tad bit warmer than the air, NO condensation I would imagine.
What brand of boat dehumidifier are you using and how do I find one to buy?
Old Nov 6, 2025 | 10:14 AM
jtmull's Avatar
jtmull
Stage I
Default Harley storage air bubble
Anyone using the storage air bubble? I bought it and will be storing my bike for the winter months inside the storage bubble inside an unheated shed.
Old Nov 6, 2025 | 04:13 PM
Bass Player's Avatar
Bass Player
Sea Foam in the gas (full tank) and I take the seats off all 3 bikes. Fan runs year round, no covers.
Old Nov 6, 2025 | 07:09 PM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
I mentioned this in another thread steel wool in the exhaust, the pipes are great storage for seeds and nuts.
Old Nov 6, 2025 | 07:21 PM
Riffraff123's Avatar
Riffraff123
I have same, insulated but unheated garage for last 15 years. I park on a piece of outdoor carpet, cover with a quality breathable dust cover and put a 40 watt drop light under the cover. Wood plugs for the pipes, and stabil marine in non ethanol 90 octane, run about 10 minutes to get it in the carb. Never problems with condensation and starts easy for a quick warmer day in the winter or in the spring.
Ride easy! Edit to add...remove battery and bring in the house.
Old Nov 7, 2025 | 12:14 PM
Old New Rider's Avatar
Old New Rider
Originally Posted by twoglides13
You can buy "air dryer" products to hang in your garage. They suck the moisture out of the air.
If you have electric power out there maybe you could run a dehumidifier in addition to desiccant packages? That would only work down to freezing of course, but below freezing temperature would condensation be a problem? Air is usually pretty dry when super cold.
Old Dec 17, 2025 | 08:59 AM
Medevack1's Avatar
Medevack1
I'm in Winston Salem NC. The winters can be bad but not extreme, I have a 23 SGS and a 06 Sporty that I keep in an indoor fully enclosed garage that's attached to the house, the temperature doesn't get below 50 degrees; However I do winterize both bikes with fuel stabilizer and cover them up with battery tenders. I've never had any issues with condensation or mice I'm guessing because i think we have a black snake somewhere in the property lol
Old Dec 25, 2025 | 11:01 AM
hardheaded's Avatar
hardheaded
My brother keeps his bike on the family room. No problems with any moisture at all, unless he spills his beer on it.
Old Dec 25, 2025 | 12:08 PM
twoglides13's Avatar
twoglides13
And that's right where it should be for the winter!!!
