Spark Plug Cleaner...
Old Jun 22, 2025 | 07:59 AM
bustert's Avatar
bustert
a couple of "K" ???
what are your boost pressures?
hd is like any other engine so a few miles is child's play.
service requirements are suggestions, after all the moco does not want a bad rap and besides it ='s $$$$$
one of the best ign diagnostic tools you can have is an Oscope and the pocket variety are cheap.
Old Jun 23, 2025 | 07:47 PM
NorthWestern's Avatar
NorthWestern
With all the changes I constantly make on my bikes, I decided it was time to buy a spark plug cleaner.. What I'm starting to learn is that with my Power Vision tuner, I can't solely rely on Data logs to determine what the problems are as in my last post in the General Topics section.. Spark plugs tell the entire story and with all the changes I make buying new plugs every time can get a little expensive.. It's not that the plugs are expensive @$6.00 a piece but when you need fresh clean plugs to identify any problems it can add up after making changes several times.. So I ordered a cheap unit off of Amazon.. I looked at some videos and it appears to work ok, so for $20, I said just do it.. Look at it this way I have 6 sets on OEM plugs on the shelf that have less than 500 miles on them.. IMHO This cheap little unit already paid for itself..
https://www.amazon.com/dp/B0D7GG63WR...fed_asin_title
Man, I have not seen one of these in years! Used to clean my Accels with the one we had in tech class for my Mustang.
I wonder if cleaning iridium plugs is a no-go? I have never considered it, but I can't imagine a reason not to. I have a few sets (brands) that I have pulled with a few K on them that I experimented with during the engine build, etc. 4 goddamn overpriced iridiums per change certainly adds up!
I have an Amazon gift card from Father's Day burning a hole in my account...I might have to try this just because. @98hotrodfatboy thanks for finding this, man!
Old Jun 23, 2025 | 11:23 PM
djorgensen3's Avatar
djorgensen3
My dad had one 35 years ago that we used all the time. We did have to check them over real good to make sure there was no sand wedged down deep inside of them. Saved lots of plugs with that dang thing on the 64 ironhead and 70 shovelhead.
Old Jun 24, 2025 | 06:23 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Mmmhmm. I had one way back in the era of crude carburetors and such. When we frequently carried a spare plugs and a set of points. And like you, I had to be careful about the blasting media getting stuck deep in the plugs. With the modern plugs and fuel injection, I just haven't used it in many years. Not even sure I even still have it. For those few old machines I still have, I'd rather just replace their plugs every few years.
Old Jun 24, 2025 | 07:42 AM
470004's Avatar
470004
I still have the one I purchase back in the 70's when I worked a auto parts store. It's still working great.
Old Jun 24, 2025 | 08:28 AM
Goose_NC's Avatar
Goose_NC
I don't think I've ever put more than a couple thousand miles on any of my plugs but now that I have a cleaner they might see more miles.. Yes edges are very sharp not rounded..
A couple thousand miles? Are you 90? Do you change your oil at the same intervals?
Plugs for the past 20-30 years, and longer, are better then the previous plugs from the 1960s. Especially with most motorcycles having electronic ignition, if not EFI. Except for antiques, who is running points and condenser today?
Gone are the days of needing a tune-up every 1000 miles.
Old Jun 24, 2025 | 09:30 AM
Max Headflow's Avatar
Max Headflow
Your missing his point.. He simply wants clean plugs for tuning..
Old Jun 24, 2025 | 10:19 AM
Uncle Larry's Avatar
Uncle Larry
Okee dokee ... Who'd like a Snickers bar? ':>)
Old Jun 24, 2025 | 10:30 AM
NorthWestern
That is what I recall as well.
I just wanted a cool way to clean up these few sets I had needlessly rotated through, and did not want to use the sand blaster at work on the iridium center electrode, it would likely blast it clean off.
Old Jun 24, 2025 | 10:46 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Thanks Max appreciate the backup... Obviously comprehension is a thing of the past nowadays...
