‘24 + Rider Backrest Mod
Old Jul 4, 2025 | 01:23 PM
scj's Avatar
scj
Default ‘24 + Rider Backrest Mod
I haven’t researched rider backrests for the ‘24 CVO RG so when I went to the dealer yesterday, I asked if they had a rider backrest for my bike, they sent me on my way with parts and to my surprise, the kit said “does not fit ‘23 later”. I did a little research and to my surprise, they don’t offer one. Since nothing seems to be readily available, I did a little trial fitting and decided, a couple of bends in the backrest posts and a notch cut out of the seat base, I have a rider backrest.
You mount the fender bracket in the most forward position, otherwise, the passenger seat front brackets will not reach the mounting studs. Then make one bend on the backrest posts just above the fender bracket, bending it towards the rear and the other bend, forward, right at the top of the seat. Kind of Z shaped.
The post are hardened so get the torch out and remove the pad from the seat post to keep from burning your pad material.
I took an oscillating cutter and notched the seat base in between the mounting holes to clear the fender bracket. No need to cut the seat cover material as it stretches right over and around the bracket.
Took me about an hour and a half to get it figured out and modified but it looks factory when all said and done.
I had to redo the bottom bends to get it exactly where I wanted the backrest. That’s why you see the burnt paint on the post. I had to repaint it once I was happy with it.
hunter1jonathan
Apr 29, 2013 12:19 PM
Mr.Softy
Nov 19, 2010 04:00 PM
thehueg
Jun 18, 2008 12:33 PM
300potato
Dec 25, 2007 11:01 PM
