Tools
Old Feb 14, 2005 | 02:46 PM
Steeltown's Avatar
Steeltown
Default RE: Tools
It's exhaustive but this was given too me by a wrencher...
Small flashlight
3/8" ratchet
4" drive extension (x2)
Spark plug socket
5/8, 9/16, 1/2, 7/16, 3/8, and 3/8" (the 3/8" is a 12 point for the caliper bolts)
3/8" hex (allen) socket (for the timing plug)
5/16" hex (allen) socket (rocker arm plugs - shovel)
6" adjustable wrench
10" adjustable wrench (with a little ground off the handle to fit it easily into the pouch)
9/16 x 5/8 starter wrench (thats the curved one for the pre-evo heads and base)
5/8 x 9/16 open end wrench
1/2 x 7/16 open end wrench (x2, need two to adjust lifters)
3/8 x 7/16 flare wrench (for brake fittings)
5/16 end wrench
1/4 end wrench
5" vise grips
feeler gauges
spark plug gauge
very small straight screw driver
4-way screw driver
small set of allen wrenches
4" sidecutter
emergency clutch cable repair clamp
clutch spring retaining tool (just a big washer, so I can pull the clutch on a pre-evo bike)
12 VDC test probe
Small assortment of nuts, bolts, washers...couple of small hose clamps...some electrical connectors...wire ties
Electrician's tape
Small roll of mechanics wire ("baling" wire)
Small roll of "match solder" (no kidding, electrical solder that melts with a match)
Book of matches
2 master links and a half link
pocket chain-breaker
Copy of my wiring diagram
Clothespin
Spare spark plugs
Old Feb 14, 2005 | 02:55 PM
MoesSS's Avatar
MoesSS
Default RE: Tools
Damn Steeltown, sounds like you need a truck to carry all that. [sm=icon_cheers.gif]
Old Feb 14, 2005 | 03:08 PM
Steeltown's Avatar
Steeltown
Default RE: Tools
LOL, I hear ya...I felt the same way...my buddy says he can fit it all in, and actually explains in detail how he does it....
Old Feb 14, 2005 | 03:14 PM
MoesSS's Avatar
MoesSS
Default RE: Tools
I will worry about that when my bike is out of warrenty.
Old Feb 14, 2005 | 03:21 PM
Steeltown's Avatar
Steeltown
Default RE: Tools
Yeah, keep your cell phoned juiced and your warranty card handy
cheers
Old Feb 14, 2005 | 05:11 PM
Phil R's Avatar
Phil R
Default RE: Tools
Thanks for the tip. Just went on line to Windzone and ordered a kit. Looks pretty good at a fair price!
Old Feb 14, 2005 | 08:39 PM
Blue SOG's Avatar
Blue SOG
Default RE: Tools
ORIGINAL: Phil R
x2
paulhog
Sep 9, 2025 01:03 PM
edjack
Nov 2, 2012 09:18 AM
bsljacques
Sep 13, 2011 08:24 AM
Scottla
Aug 16, 2010 10:41 AM
ord sgt
The General Motorcycle Forum
30
May 12, 2009 08:34 AM
