dot 5 brake failures-fl models
Old Jun 12, 2006 | 12:10 PM
Prw3's Avatar
Prw3
Default RE: dot 5 brake failures-fl models
Well I do see the logic, sea level air and bleeding would be very different at 8500. Im no expert but I can see there being a potential issue
Old Jun 12, 2006 | 06:02 PM
sleepneagle's Avatar
sleepneagle
Dot 5 fluid dissipates heat better than DOT 2 or 3. DOT 5 is silicone base so it doesn't absorb moisture. I live in the south with 95 degree days, pavement temps can reach 140. rear master sits close to the front head pipe. I haven't had any problems.
Old Jun 12, 2006 | 06:39 PM
Longtimegone's Avatar
Longtimegone
Thanks for posting the additional info, Mason. Ya came through, buddy.
DOT 5 is more spongy-feeling than DOT 4 anyway. Additionally, the front brakes are difficult to bleed completely. Takes a lot of pumping, adding fluid, and more patience than most people can muster.
You may want to try this reverse filling processon your bikes:
http://www.moccsplace.com/images/bra...er/bleeder.htm
It forces the air out the top of the system as you fill it rather than trapping it in the system.
I for one do not understand why Harley switched to DOT 4 from DOT 5. On a motorcycle, DOT 5 seems to be so much more friendly and easier to work with. You got any insight into why H-D made that change?
Best of luck ... ride safe!
Boat Tail
General Topics/Tech Tips
17
Oct 23, 2019 04:16 AM
14U24ME
Mar 30, 2009 07:40 AM
incrediblah
Dec 27, 2007 08:40 PM
jonnyrotton
Dec 22, 2007 10:42 AM
HDF Tech
Aug 8, 2005 05:21 PM
