Potential Problem - Digital Oil Temperature Gauge 62955-09
Old Aug 20, 2010 | 08:59 AM
MCT's Avatar
MCT
Default Potential Problem - Digital Oil Temperature Gauge 62955-09
Just a heads up in case you are planning on purchasing the 62955-09 digital oil temperature gauge. I purchased one for my wife's new Softail and before installing it I pressed the readout button. It would not stay lit unless the button was continually pressed. It would immediatley shut-off once it was let go. Obviously this is not correct as it should stay on for about ten seconds. I could not get it to go into extended lighting mode at all by pressing twice. I later went back to it and it would then work correctly. Shortly thereafter it would become intermittent again.
I then had the dealership send me a new one, (they are 125 miles away), and I received it yesterday. This one did exactly the same thing. Both of these have a date code on the package of 06-02-10. I called H-D Customer Service this morning to see if they have had any issues, but advised me they have not at this time. I can see one of these maybe being defective but not both. I have three of these on my other bikes and have never had a problem with any of them. In fact, I haven't even replaced the battery in any of them and two are eight years old.
Just make sure before you purchase one of these that it operates correctly. Try it several times to make sure it stays lit for the prescribed amount of time, one button push - about ten seconds, two pushes - about two minutes. I guarantee you if it is intermittent, but operates correctly several times in a row, it will still be intermittent later.
I did not want to crack this open to replace the battery, just in case they had a bad batch of batteries. H-D Customer Service advised if I wanted to try this I could without any return issues.
Old Aug 25, 2010 | 05:40 PM
Teeper's Avatar
Teeper
4th Gear
I also have one on my 09, love it. What does your read after a decent ride?
I was stuck in Toronto traffic a couple weeks ago, air temp was about 90 degrees F and the cylinder deactivation was working i believe, by the time I got parked in my condo it read 308 F, I am concerned the fuel map installed after changing the pipes and AC is way too lean.
Old Aug 26, 2010 | 06:48 AM
MCT's Avatar
MCT
On my hottest running bike, '08 Fat Bob 96 TC, on a hot day I get 237-241 with an oil cooler, which I think is still too hot. You are cooking your oil and engine, as well as creating deposits. I have never seen or heard of a temperature that high in one of these engines, though I am sure it can be done. I think you are running lean and hope you are running a synthetic oil.
Old Sep 4, 2015 | 11:01 AM
JohnRichard's Avatar
JohnRichard
Do those digital dipsticks fit a 91 Softail?
Old Sep 4, 2015 | 11:14 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
That temperature range is completely normal. You are not cooking the oil and engine. It's the oil that's taking the heat build-up out of the engine not just the cooling fins. To the OP you may be pushing/ holding the button down a little too long on the gauge. Never had a problem with mine.
Old Sep 5, 2015 | 07:38 PM
MCT's Avatar
MCT
You need to read the post above mine concerning the 300+ degreee oil temp. That IS cooking the oil and that is what I was referring to.
Old Sep 6, 2015 | 06:02 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Save your money, your engine (Evo) will not heat oil like a TC engine does.
If you really want to know what the temp is, I suggest you try one of those inexpensive analog dial dipsticks first.
https://www.denniskirk.com/H40102.sk...ad=45713335117
Old Sep 7, 2015 | 08:44 AM
MCT's Avatar
MCT
John, my '88 FXRS I used to have ran very cool. I could only find an analog dial-type gauge for it. Sorry I missed your post from the other day.
Fatbob usmc EOD
Mar 30, 2014 12:04 AM
W4MAC
Shovelhead
15
Apr 13, 2013 05:33 PM
toastman
Aug 6, 2012 02:51 PM
LocoPilot750
Jun 10, 2011 11:23 AM
AK BAGGER
May 4, 2010 12:21 AM
