Tips for Winter Storage
Old Nov 3, 2010 | 12:35 PM
tankplunkett's Avatar
tankplunkett
I notice that most of you live up north, but down here in southeast Texas, I just ride through the winter. Its kinda nice not getting below 40 degree's very often!
Old Nov 3, 2010 | 01:46 PM
glideridemike's Avatar
glideridemike
Originally Posted by JohnnyC
Does anyone shut off the petcock and run the motor until all the gas has run out of the carb and the bike stalls?
I've done this with all of my yard equipment. Gas has a tendency to gum up things when it sets for long periods, especially in cold weather.
Never have myself. Like I said, I add Seafoam to a tank and run most of that tank out getting the treated gas up into the carb. Then I always fill it back up with the appropriate amount of Seafoam to protect that tank of gas. Some years back I had an old 750 Kaw which sat in my shed for 11 years. Back then there were no 'sprays' for the cylinders, but Bardahl used to make a lube to go in your gas called 'Upper Cylinder' iirc. Before parking the Kaw I added that to the gas and ran it down to damned near empty, then added another can to the little bit of gas left, then ran it all out til the bike quit. I also pulled the plugs and shot some oil in each cylinder and turned in over a few times by hand putting the plugs back on when I was done. Of course I never thought it would be 11 yrs sitting, but when I pulled it out, r& r'd the tires, battery, oil and filter, plugs and filled it with gas, it started back up and ran great.
Old Nov 3, 2010 | 08:41 PM
flhpi06's Avatar
flhpi06
5th Gear
Talking
I hope you get a sunburn in January too!!! Thanks for rubbing it it.
babaharley
Nov 5, 2017 10:03 AM
studiopeg
Dec 19, 2011 11:04 AM
tandt
Dec 6, 2009 02:56 PM
capnjim01
Nov 22, 2006 10:11 AM
blackbob
Sep 6, 2006 06:30 PM
