Pre Riding Tips
Old Jun 27, 2005 | 02:30 PM
HDF Tech's Avatar
HDF Tech
Default Pre Riding Tips
Hope everybody is enjoying the summer. For this tip I’m going to bounce all over and hit some of the simple stuff that can make a big difference
AIR/FUEL - When you buy your new pipes and air cleaner be sure you address your air/fuel mixture. You will more than likely need to have your carb re-jetted or the pulse length of your injectors changed. Dyno’s with air/fuel sensors and load control are an excellent way to diagnose & correct your fuel. Your bike will not perform at its best until your air/fuel is correct. Remember the desert is not the best place to run your bike lean.
WARRANTY - When it comes to buying your parts or having your service done, you CAN use aftermarket shops and parts and it won’t affect your Harley Limited warranty. In a February 2003 article in American Iron, a Harley spokesperson reinforced that statement. The only catch is if the after market part or service causes the failure of the Harley warranted part, then the warranty for that part may be void. There are many good bike shops throughout the valley that will be happy to help you customize your bike, do your scheduled services and even do warranty work for you. The best part is more than likely they will save you money if you give us a shot.
TIRES - People, check your air pressure. I would suggest you check or have it checked frequently. You would be amazed at some of the tire pressures we find people riding on when they bring their bike here to the shop.
FLUIDS - How do I check my oil and transmission fluid? Always follow the manufactures directions but a rule of thumb is oil should be checked on level ground and with the bike on its kick stand for rubber mounted bikes and in an upright position with frame mounted motors that have oil tanks beneath the seat. Check your transmission fluid with the bike in an upright position.
Source: http://www.azbig.com
geads
Carburetor Related
37
Apr 3, 2024 07:49 PM
AAAC
EVO
16
Apr 9, 2014 10:37 AM
J Hester
Apr 20, 2013 10:30 AM
exiledcarper
Dec 18, 2009 05:11 AM
glide2005
Nov 18, 2008 07:03 AM
