Can't get my Evo to start
Old Nov 5, 2011 | 08:39 AM
OB1's Avatar
OB1
Stage II
Default Can't get my Evo to start
Ok, here is what I got...90' Evo, S&S Super E carb, DynaTech Single fire ignition. *The bike has been running but stalled out and have not been able to get it running again. *Carb is set as follows...idle mixture screw 1 1/2 turns out, idle just engaged then 1/2 turn, accelerator pump screw lightly set then 2 turns out. *Set the ignition using the static timing recommended by DynaTech...both coils are reading correctly with the ohm meter...so, I am getting spark, I am getting fuel and I am getting compression...suck, squeeze, bang and blow...everything seems to be in order so why won't the damn thing start? Any help would be greatly appreciated
Old Nov 5, 2011 | 10:02 PM
OB1's Avatar
OB1
Stage II
...update...put in some new plugs and started right up...
Old Nov 8, 2011 | 08:45 AM
grbrown's Avatar
grbrown
Well done! And welcome to HDF from the UK. Call into the Evo forum and meet up with fellow Evo owners.
mdazb
May 20, 2018 01:19 PM
BmanRRT
Jul 22, 2015 12:08 PM
Tari FLH
Shovelhead
Feb 13, 2013 10:19 AM
nolagreen
Dec 31, 2010 03:19 PM
mjdflhr
Exhaust System Topics
Jul 25, 2009 08:46 AM
