Winter storage tips?
Old Nov 18, 2011 | 10:42 AM
blackchipjim's Avatar
blackchipjim
Default Winter storage tips?
I know it's a bitter subject but some of us live in climates that require us to put our bikes to sleep for the winter. I know the basics for the most part but I have a few other questions. If I have to store the bike in my unheated garage and not the living room what's the best way to store it so it doesn't show up like crap in the spring. I want to take the seats off and polish everything up before throwing a storage cover over her. I'll bring the battery inside and charge it up once a month. Should I do anything else to protect her?
Old Nov 19, 2011 | 12:41 AM
OLD 96's Avatar
OLD 96
Maybe spray her down real good with WD40? Put her up on blocks to get the weight off the tires? You know to drain the gas and oil? Right?
Old Nov 19, 2011 | 06:45 AM
Captain Bligh's Avatar
Captain Bligh
I have never drained the gas and oil in 40 years of motorcycling. To the contrary, fill the gas tank up to the brim and add fuel stabilizer. When the gas tank is full, there is no room for condensation. Have you ever looked at a used bike to see rust inside the gas tank and wondered why? Condensation.
Here is what I do:
  1. Thoroughly wash bike.
  2. Wax painted and chrome surfaces.
  3. S-100 engine bright on the jugs.
  4. Stuff the exhaust pipes with steel wool and cover them with a sock to keep rodents from nesting.
  5. Raise it up on the jack (in my case to fit into a tight spot in the garage)
  6. Plug in battery tender jr.
  7. Cover with breathable cover.
  8. Don't start it or unwrap it until spring.
You will hear lots of folks advise changing the oil before storage. Sometimes I do; sometimes I don't. Never seemed to matter.
Old Nov 28, 2011 | 07:34 AM
grbrown's Avatar
grbrown
A friend of mine puts his Harley in a protective bag, complete with dehumifier. They are available for 'classic' or antique bikes. Worth a look.
Added later:
Here is an inflated bag, but I have also seen vacuum bags.
Old Dec 19, 2011 | 10:26 AM
blackchipjim
Default battery charging
I have the bike on jack stand to keep the tires off the ground. I'm still going to work on her during the winter and maybe even get a ride in or two so I don't think I will use the stabil in the tank. I do have a question though. I have storage cover made of cloth and wonder if the trickle charger on the battery will give off enough corrosive gas to damage the cover or the bike in general?
Old Dec 19, 2011 | 07:50 PM
smitty901's Avatar
smitty901
Put the Stabil in , if your using a tender and not a charger you should have no problems, Modern tires don't need to be off the ground. but it don't hurt.
This stuff is not a bad idea if your parking it for awhile .
Bluesy883
General Topics/Tech Tips
11
Oct 30, 2016 10:01 AM
Mikey8717
Oct 11, 2013 10:14 AM
pheur
Sep 28, 2011 09:52 AM
kelton3
Jan 15, 2009 04:40 PM
forever young
Nov 7, 2008 12:02 PM
