Will Try And Answer TECH ?
Old Mar 9, 2004 | 10:31 PM
Harley Dude's Avatar
Harley Dude
Default Will Try And Answer TECH ?
Hey Everyone,</P>
Just graduated from American Motorcycle Institue. Still only a entry-level tech but I will try my best to help. If I can't figure the problem out I have CONNECTIONS!!!!!!!!!!!!!! Or if you are close to my area we'll try and hook-up and try and get you running again. </P>
I'm located in NorthWest Ohio</P>
Or feel free to e-mail me at panther27@hotmail.com </P>
Steve</P>
Old May 2, 2004 | 02:55 AM
goose's Avatar
goose
Stage I
hey panther</P>
got an 03 duece,(carb) and am getting ready to install v&amp;h longshots with a stage one kit. woundering what else I could be putting on . just looking for ideas.</P>
Old May 31, 2004 | 08:17 PM
Keith Gleason's Avatar
Keith Gleason
Stage II
When I try to start my bike it clicks, wont turn over, Lights work etc, battery isnt that old. Please reply with suggestions.
Old Jun 4, 2004 | 11:11 PM
JoFrealy's Avatar
JoFrealy
Stage I
Harley Dude,</P>
I have a 97 FLX with 9300 miles. I started to hear a knocking sound coming from the primary cover area. I check the chain and it was w/in specs. Everything was riding fine until I took it for a short ride to get an idea of what was going on. About 1/2 mile into the ride I lost exceleration, not from the engine it was running fine. The clicking got louder and I stopped. I turned the engine off, kept it in gear and pushed it forward. I felt little to no resistance and still had the clicking noise. Any ideas? </P>
Old Jun 5, 2004 | 05:33 PM
harley09's Avatar
harley09
Stage II
<SCRIPT language=javascript>postamble();</SCRIPT>
<DIV><FONT face=Arial size=2></FONT></DIV>
<DIV><FONT face=Arial size=2>I have a 2001 FXST. I put the bike away over the winter with a trickle charger on it. I noticed when I brought out the bike today that the charging system said the battery needed a charge. So I hauled it out and gave it the normal 4 hours at 3 amps.</FONT></DIV>
<DIV><FONT face=Arial size=2>I put it back in and tried to start it. Nothing happened. The lights go on, the alarm system works but the starter does not work. I heard the battery sort of hissing below me. So I hauled it out and charged it again.</FONT></DIV>
<DIV><FONT face=Arial size=2>I just tried to start it again, but the same thing. Lights and alarm work, but the battery just hisses. No starter noises at all.</FONT></DIV>
<DIV><FONT face=Arial size=2>What do you think this is? Is the alternator gone? Or regulator? </FONT></DIV>
<DIV><FONT face=Arial size=2>My shops don't open around here until Tuesday. I really would like to ride!</FONT></DIV>
<DIV><FONT face=Arial size=2>Can you offer any suggestions?</FONT></DIV>
<DIV><FONT face=Arial size=2>Thanks,</FONT></DIV>
Old Jun 5, 2004 | 05:52 PM
Scotty's Avatar
Scotty
Stage I
I have a 1997 Harley Classic. I bought it used in 1999 from Chicks Harley in Albuguerque. I have had trouble off and on ever since I bought it. After starting it and going a short distance it would cut off and the engine light would come on. It would start back up and be ok. Then as time went by it started blowing the radio fuse by kicking the breaker until it reset. It would run fine after that. I put a 50 amp breaker in which seemed to solve the problem. Then it started again in which the electricfuel pump went out. I repaced that in which I thought that solved it. Know it has done the same thing. The one thing I have noticed is when it is hot around 80 degrees up is when it does this. I have had it over to Chicks in which they did nothing. I would appreciate any insight.
Old Jun 14, 2004 | 10:07 PM
rednec's Avatar
rednec
Stage III
hey can you help with my bottom end problems?ifso email me at rednec772003@yahoo.com
Old Jul 7, 2004 | 12:21 PM
Hangaround's Avatar
Hangaround
Stage I
Hey Harley Dude.</P>
Got an 04 FLHTC and I'm preparing to do an oil change. I want to make sure I don't drain the trany oil, do you know were is the engine oil drain plug?</P>
</P>
Thanks</P>
Old Sep 6, 2004 | 06:08 PM
Topsail's Avatar
Topsail
Default RE: Will Try And Answer TECH ?
Harley Dude has left the building?!
Old Sep 10, 2004 | 12:35 AM
cowboy Harry's Avatar
cowboy Harry
Wow , the questions are piling up.
