Recommendation (or Not) for Cable Luber
Old Jan 15, 2007 | 09:36 PM
OneBlackFly's Avatar
OneBlackFly
Default Recommendation (or Not) for Cable Luber
Does anyone have an opinion on the usefulness (or otherwise) of the small, clamp-like devices used to inject cable lube into cables? They appear to be a good tool, just wonder how they work. A spray nozzle with a long tube misses more than it hits (from my experience). Thanks.
Old Jan 15, 2007 | 10:00 PM
wesd41's Avatar
wesd41
Default RE: Recommendation (or Not) for Cable Luber
I have one and use it regularly. Big improvement over trying to spray lube directly into the cable sheath. It was worth the 14 bucks it cost me (including the can of lube).
Old Jan 15, 2007 | 10:03 PM
OneBlackFly
I thought it would be useful. So which one do you have and which lube do you use? Thanks.
Old Jan 15, 2007 | 10:35 PM
thrillseeker's Avatar
thrillseeker
Dri Slide comes with a little needle applicator that you just stick into the sleeve of the cable.
Old Jan 15, 2007 | 11:14 PM
OneBlackFly
And Dri-Slide contains graphite (black) which could make a mess of H-D Diamondback braided cables. No thanks. I'd use a clear lube, like Gunk Teflon or WD40. Hence the use of the cable luber since those two lubes don't have a needle to them.
Old Jan 16, 2007 | 01:06 AM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: OneBlackFly
Don't use WD-40. It dries. It is a poor lube.
Rem Oil works great.
Old Jan 18, 2007 | 01:07 AM
Purple Thunder's Avatar
Purple Thunder
30W motor oil works well dripping out the end of a squirt can, take a while but thats how you lub cables. I have always done it about every 5/7000 miles. Never had a failure Mark H. Otto NC
Old Jan 18, 2007 | 02:08 PM
recross's Avatar
recross
Marvel mystery oil.......if it came in a spray would push it thru the luber....a good product for the $$...
Old Jan 19, 2007 | 01:17 AM
wesd41's Avatar
wesd41
The one I bought (from Dennis Kirk, if I remember correctly) is called ProtectAll. Kit included the cable clamp/luber and a can of cable lube.
Before I bought that, I used WD40 for many years on many bikes. It's good for cleaning out grit and rust, and it does leave a film behind after it dries. Spray some on your hand and let it dry and you'll see whatI mean. Anyway, WD40 is especially useful in a climate like winslow (dry and dusty) because it tends not to collect and hold grit.
Wish I could say the same about my black paint.
Old Jan 19, 2007 | 03:17 AM
OneBlackFly
Exactly the same one I just bought from Dennis Kirk too. From my experience with covers over adjusters, both clutch and throttle/idle, the covers trap dirt and moisture, so I decided to take the covers off and spray/wipe Protect-All or the like on the adjusters to protect them. Easy to do every few days or as needed after I wipe clean the adjuster. That way, I won't have a frozen solid, hence broken clutch adjuster, also known as an all-new cable.
