Odometer is wrong
Old Oct 23, 2012 | 11:18 AM
nmg1972's Avatar
nmg1972
Default Odometer is wrong
When I went to ride my 2005 Springer Classic this morning, my odometer has my mileage as 848614.
Is there any way to fix this back to the true mileage?
Old Oct 23, 2012 | 11:21 AM
ElectraGlideSteve's Avatar
ElectraGlideSteve
Are you saying that overnight the mileage on the odometer changed?
If so, what do you attribute that to? What do you think the mileage should be?
Unless you can prove what the actual mileage is, changing the odometer (if possible) could be considered fraud. JMO
Old Oct 23, 2012 | 11:24 AM
Scrmnvtwins's Avatar
Scrmnvtwins
I believe there was another post on here for this same issue and a Hd tech stated the bike computer has the actual mileage so it can be restored
Old Oct 23, 2012 | 11:39 AM
nmg1972's Avatar
nmg1972
I'm sure that I did not put 800000+ miles on my bike. I should be around 32000ish. I bought the bike used in April 2011 with I think 21k or 24k miles on it. It has had only 1 oil change so far which was done at 4500. Since the oil change I put about 3600 on.
As to what attributed to it, I have no idea.
Scrmvtwins: So I can take it to the dealership and have it restored to it's actual mileage then? That's a relief.
Old Oct 23, 2012 | 11:47 AM
Scrmnvtwins
Call your dealer to confirm as I just recall this issue being posted before and a follow up post stating the computer had the actual mileage. I don't recall what the root cause was but it sounded like they would be able to get restored to the proper mileage.
Old Oct 23, 2012 | 03:28 PM
No Name Motorcycle Shop's Avatar
This is correct that the newer models store the odometer reading via the ECM. I am not 100% that an 05 falls in this category but you may try unplugging the connector on the back of the speedo then plugging it back in to see if it resets to the proper odometer reading. Otherwise you may be looking at having to purchase a new speedo.
ramblin5
2014-2024 Touring Models
89
Apr 2, 2015 08:43 PM
lh4x4
Mar 4, 2014 07:37 AM
harleyglen
Sep 24, 2013 01:05 PM
desertwolf
Sep 28, 2010 07:14 PM
duoglider
Apr 26, 2009 01:44 PM
