Winter Storage Question
Old Nov 16, 2012 | 06:46 AM
dewey081's Avatar
dewey081
1st Gear
Default Winter Storage Question
Good day,
I put my Seventy Two up for the winter in my garage (where will not drop below zero deg C or 32 deg F). Put fuel stabilizer in with a full tank, ran it for a few miles/kms and have the battery (still installed) on trickle.
My question is; Can I cover the bike with an aftermarket bike cover with the battery being trickled? The reason I ask is I worry that some corrosive gases may be vented or created during the charging or trickling, and I don't want those gases , if generated, to affect my bike under the cover. My thought process is that the battery is a sealed unit, therefore should not vent; however I do not want to take any chances.
Your thoughts....
Thx
Old Nov 16, 2012 | 07:38 AM
Tailgunner1's Avatar
Tailgunner1
Use a cover and battery tender every winter the bike had to be put up (many times). No problems.
Old Nov 21, 2012 | 06:40 AM
grbrown's Avatar
grbrown
Your owners manual gives tips on winter storage. In the garage your bike only needs a dust cover which is porous, so any gases given off will do no harm.
You say 'trickle', which if true is not a good idea. A battery tender, that monitors the battery and charges it as necessary, is much more suitable.
My bikes all have their own tenders and have simple covers.
skully1200
Nov 25, 2011 02:11 PM
DarrellDeluxe
Jan 30, 2011 01:00 AM
puyallup
Nov 4, 2008 03:29 PM
mdxd62
Dec 3, 2007 01:58 PM
HDNJ1200R
Jan 24, 2007 04:34 PM
