General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Tearing apart my speedo, the speedometer works fine, the odometer is creeping along at 1/10 actual. I'm at this point in assembly, and I cannot seem to get the odo reset shaft off to remove the mechanism from the bucket. I haven't broken anything yet, and I'd like to keep it up, suggestions?
To remove the reset shaft, you'll need a tiny phillips screwdriver. Try using an eyeglass frame screwdriver.
It should take an "0" size Phillips with a long shaft. It often is seized on the shaft. Maybe spray with some penetrating oil. Using a small hammer, and being certain the phillips is seated, tap on the screwdriver head. This often helps to break it loose.
