General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
60 mph takes exactly 60 seconds between 1 mile markers on the freeway. Every bike i've owned is just slightly under that as indicated. ( 60 mph is really closer to 59 or so. No big deal.)
Of the two, the gps will be more accurate. Your speedo is driven off the trans, so is dependent on rear tyre diameter, which will change from brand new to worn out by 2-3% throughout its life, also have subtle changes in diameter if solo or 2-up. In addition manufacturers of vehicles are not required to make their speedos particularly accurate, probably no better than +5%.
