top box repair
Old Aug 6, 2013 | 12:39 AM
Ken Oaff's Avatar
Ken Oaff
Default top box repair
top box is cracked by front hinge - usual place where they fail because of overloaded carrier on open lid being unsupported
can normal fibreglass matting / resin be used to effect repair to inside of box
Old Aug 6, 2013 | 08:13 AM
grbrown's Avatar
grbrown
Wink
Depends what your box is made of. Older ones are indeed glass-fibre, but newer ones are abs plastic or similar. If yours is g/f I am sure it can be repaired as you suggest, but if abs, there are firms who can weld repair it, common for sport bike owners. I've never heard of them failing and mine is decades old!
Old Aug 6, 2013 | 12:49 PM
Ken Oaff's Avatar
Ken Oaff
do you know when they changed over from fibreglass to plastic?
Old Aug 6, 2013 | 12:53 PM
grbrown's Avatar
grbrown
No Ken, I don't. I have seen it discussed on HDF in the past, but don't recall the year.
Old Aug 6, 2013 | 11:58 PM
Ken Oaff's Avatar
Ken Oaff
have just drilled holes in base of box to fit quick detach brackets it appears to be fibreglass
will attempt fibreglass repair, if its plastic the fibreglass won't adhere and I';; be back to where I started
Old Aug 7, 2013 | 06:39 AM
grbrown's Avatar
grbrown
They're double-mould formed, a technique used by BMW for many years as well, possibly others.
blacktop37
Sep 3, 2025 05:13 AM
wavesnwheels
Apr 21, 2015 03:54 AM
swifty
Air Suspensions
Aug 20, 2014 07:40 PM
WiscoKid
Powdercoat & Paint
Mar 17, 2014 06:28 AM
bluffalobob
May 10, 2010 07:38 PM
