Dropped screw into engine
Old Aug 3, 2014 | 04:22 AM
Matthiatron's Avatar
Matthiatron
Stage II
Default Dropped screw into engine
Hey everybody, I'm new to HDforums.
Anyway, I recently bought a 2014 XL883L. I was installing a Kuryakyn air cleaner and to get to a few screws you have to take out the injectors. I messed up and forgot to cover those open holes, and dropped a screw right down the port in the front cylinder. My first action (after cursing profusely) was to try to fish it out with a magnet on a flexible arm. No luck, since the screw turned out to be nonferrous (tested on an identical screw). I next tried duct tape, sticky side out, on a wire, but that didn't work either. I can hear the screw moving around when I hit it with the tape, but I'm not able to pick it up. Any suggestions on how to get to it? I'm going to rent a borescope tomorrow so that I can at least see where it is, but I still have no idea how to get it out without completely disassembling the engine, which I very much want to avoid. Thanks for any help and suggestions.
-Adam
Old Aug 3, 2014 | 04:59 AM
Campy Roadie's Avatar
Campy Roadie
Save some time and pull the head. Lesson learned.
Old Aug 3, 2014 | 06:05 AM
Unbalanced Bob's Avatar
Unbalanced Bob
I don't know how large the ports are, but is there any way you could fit a narrow tube into the cylinder and snag it with some sort of vacuum? Aquarium air line, duct tape as a reducer, and a vacuum cleaner hose? That's what I'd try, anyway, even if it does sound crazy.
Old Aug 3, 2014 | 07:27 AM
Ron750's Avatar
Ron750
How big is the opening? If OP knows someone with a Shop Vac they sell microtools for them. I had some but rarely used them.
http://www.ezvacuum.com/vacuum-clean...FQowaQodglEA_w
Old Aug 3, 2014 | 10:37 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Put a blob of soft wax on a piece of coat hanger and fish around in there.
Old Aug 3, 2014 | 07:25 PM
Matthiatron
Stage II
Thanks everybody for the suggestions. I was able to get it out using a shop vac with the miniature attachments.
Old Aug 3, 2014 | 10:05 PM
Ron750's Avatar
Ron750
Great. This forum rocks, at times.
Old Aug 4, 2014 | 03:54 AM
Campy Roadie
Now that was a good idea.
Old Aug 4, 2014 | 08:31 AM
badfrogg's Avatar
badfrogg
Stage III
Default Compressed Air
Try opening the throttle all the way and fish a tube down there and force compressed air in, as much pressure as you can get and see if it comes flying out. Be careful to catch it, put a tarp around you to catch it if it dose, you want confirmation that it is in your hand and not in the engine. Good Luck!
Old Aug 5, 2014 | 12:33 AM
Ron750's Avatar
Ron750
He already got it out.
JimRicker
15
Mar 15, 2015 08:18 PM
Road Star
Exhaust System Topics
Oct 13, 2013 08:34 PM
dannybaugh
Nov 2, 2011 08:20 PM
Pauly
Jul 7, 2006 12:35 AM
piniongear
Ironhead
May 25, 2006 01:28 PM
