tail light issues
Old Aug 13, 2014 | 03:46 PM
86Drifter's Avatar
86Drifter
Stage II
Default tail light issues
So my bike decided to start having issues with her tail light. The brake lights work fine but her running light is out. I thought it mite be a bad bulb so I put a new one in and she is still having the same problem. No running light. I have taken the housing off and cleaned all the connections and checked all the wires for a loose fitting but found nothing. Everything looks fine. I had at one point just giggled the wires around to see if it was just a loose fitting and that worked for one ride but now the light is completely out and adjusting the wires does'nt work. Any ideas??
Old Aug 13, 2014 | 04:11 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What is the year and model????
Old Aug 20, 2014 | 03:02 AM
Little Mike's Avatar
Little Mike
If wiggling the wires worked once and it stays out now I'd venture to say there is a bad/broken wire someplace or a corroded connection.
hhkiwi
Apr 15, 2015 03:41 PM
Pt0872
Mar 27, 2013 01:55 PM
Yuckieboy
Nov 21, 2012 09:28 AM
RatBob13
Electrical/Lighting/Alarm
Nov 10, 2012 10:37 AM
JFonzka
Apr 24, 2008 06:46 PM
