Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Parking Brake question
Old Apr 6, 2009 | 06:04 PM
Mr. Wizard's Avatar
Mr. Wizard
Default Parking Brake question
I know the TG has a parking brake option. It looks like an umbrella handle near your right hand tire but what about the rest of us? What do you use for a parking brake?
I've been told to put my trike in 1st and in reverse and it will hold. I've talked to guys that forgot to do anything just to watch their trike roll down a hill, jump a curb and crash into some trees.
I don't like the 1st and reverse thingy... I may forget and create some issues in the tranny so I got a 12" loop bungee with a plastic ball on the end. Wrap it twice around the grip and brake handle and it holds pretty good.
What do you guys use?
Old Apr 6, 2009 | 06:18 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Only 2 Trikes are equipped with Parking Brakes, and they are NOT options HD and Lehman... That is what makes them DOT Compliant....
If you ABSOLUTELY TRUST your brake system, thaen your suggesstion is a functional and valid one... But what about a small Chock Block???
There are units that fold up flat, and take up minimal space...
Old Apr 6, 2009 | 06:59 PM
Mr. Wizard's Avatar
Mr. Wizard
Thanks for YOUR comment but I wouldn't use a CHOCK BLOCK.. I would rather it roll down a hill and crash in the trees.
Thanks for your time and consideration.
Old Apr 6, 2009 | 07:46 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
Have you tried to push your trike while its in first gear?? If your on a incline using first gear will be more then sufficient to hold the trike in place. I have been using first gear and have no problem walking away leaving the trike
Old Apr 6, 2009 | 07:51 PM
Mr. Wizard's Avatar
Mr. Wizard
It's funny you asked.. yes I have.
I try not to park it in places where I would really need a parking brake except for every now and then it could be questionable.
I was just curious what others may be doing if the time may come to need something simple or a better idea.
Old Apr 6, 2009 | 07:54 PM
BinIdaho's Avatar
BinIdaho
Parking brake I have a parking brake
Just kidding....haven't used it but once. Normally just park in 1st gear on the flats....we don't have 'inclines' around here!
Old Apr 6, 2009 | 09:30 PM
FLTR2008TRIKE
It pretty flat here at the beach too
Old Apr 7, 2009 | 04:40 AM
oldmsocko's Avatar
oldmsocko
My garage floor is pretty flat. That is where it has been sitting most on the time since November 16th.
Old Apr 12, 2009 | 10:25 AM
FLGEEZ's Avatar
FLGEEZ
I made a pla(s)tic snap buckle strap for the Loan Officer's trike. Pull on the front brake handle around the throttle. Don't trust it alone tho.... First Gear, front brake, and a better spot are her SOP.
Old Apr 12, 2009 | 10:40 AM
Mr. Wizard's Avatar
Mr. Wizard
I picked up a 12" loop bungee cord with a black plastic ball on the end. Wrap it around the brake and throttle, hook the ball. Seems to work fine. I store it in the tour pack by looping it over the manual pocket.
