Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
What Air Pressure in Tri Glide shocks
Old Apr 15, 2009 | 07:53 AM
Mr. Wizard's Avatar
Mr. Wizard
I have one of the HD pumps here as I have had several tour bikes. It's a great tool and easy to take with you on a trip. It would take forever to pump up a tire but I've seen it done on the road in an emergency. May be able to sell it that way IHP.
It really doesn't take more than a nano-second to over inflate the shocks on a tour bike and blow them. This is why I thought I would bring it up here.
I have an on board air compressor which lets me adjust the pressure on the fly. Not sure if it is an option for the TG's but may be worth looking into.
Old Apr 15, 2009 | 10:27 AM
Ironhorsepilot's Avatar
Ironhorsepilot
Hey, I just braved asking hubby how he checks the air shocks in his Ultra. Gage he says...duh!!! Well, how do you pump them up? Air pump, he says. DUH!! So what pump? My HD pump......yea!!!! We have one. Now I can get him to check the air and not worry about him blowing me up.LOL!! I know, he says I never trust him....well, let's just say I have seen some interesting moments in our life together and it is usually my stuff that gets dented, banged or otherwise screwed up!
Old Apr 15, 2009 | 12:56 PM
carlo's Avatar
carlo
Originally Posted by Mr. Wizard
It may be worth mentioning here but I am not 100% sure of the TG air ride since I have a Motor Trike.
The touring bikes have a maximum capacity of 50 pounds, again, not sure of the TG's. The recommended way to inflate the touring shocks is with the HD air pump.
http://www.latus-harley-davidson.com...n-Air-Pump.htm
Here's an aftermarket pump
http://www.debrix.com/items/item.aspx?itemid=1859248
If you try to inflate your air ride suspension with an air compressor you may cause serious damage. There is only a very small amount of air that is used and it is easy to over inflate them.
Maybe a TG owner can verify this.
Your 100% Right Max 50psi .HD air pump On Tri Glide also
Old Apr 15, 2009 | 02:02 PM
Ironhorsepilot
OK, so I ride solo. I weight 130 lbs. What should my air pressure be?
Old Apr 15, 2009 | 03:25 PM
carlo's Avatar
carlo
It's in the Owners Manual. Just you no baggage weight. Around 15-20 psi
Old Apr 15, 2009 | 04:24 PM
BinIdaho's Avatar
BinIdaho
Now I have to get an HD air pump.
Old Apr 15, 2009 | 04:54 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
Best to start with the lowest air pressure and ride to see if it bottoms out on you. If it does then you can add a little bit air at a time until it gives you a ride that doesnt bottom out and isnt so stiff you feel it up your spine
Mr. Wizard's Avatar
Mr. Wizard
It's cute, you'll love it but I don't think they come in Sun-glo. You'll have to paint it.
Old Apr 15, 2009 | 09:41 PM
cubbear42's Avatar
cubbear42
My hubby knows you're not supposed to do it - put air into your shocks at a gas station - had no other choice, looked around the area to buy a pump, checked some NAPA stores or the like - no luck...
He said he knew what he was doing...!! Have to trust him as he was a Fire Chief for over 24 years - so I didn't say anything...
It worked wonderfully as I stated in a prior post here...
Today we stopped into the Cahun Harley Dealer off I-10 near Lafayette, Louisiana - bought a Shock Pressure Pump - cost $46.95 plus tax... Yes, it's 'cute' but small enough to carry while traveling...
Their 'store' is stocked with numerous items that aren't carried by other dealers... Real nice place to check out...
HDJOE60
2014-2024 Touring Models
15
Apr 26, 2015 01:05 PM
dh2683
Jun 12, 2009 08:53 PM
hardyf111
Jan 11, 2009 01:24 PM
caorig
Sep 18, 2008 04:04 PM
Thunderchild
Mar 17, 2008 10:52 AM
