Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Test Bed Tri Glide
Old Jun 29, 2009 | 09:54 AM
carlo's Avatar
carlo
Default Test Bed Tri Glide
All Kidding A side Cub Bear and Her Husbands Try Glide. Is a good test bed as they have 13K on there Tri have ridden it in all weather and road conditions. It sits outside in the rain cold and hot sun. They ride two up with luggage. Only problem they have is a leaky trunk.
Old Jun 29, 2009 | 11:44 AM
oldmsocko's Avatar
oldmsocko
I have 2 issues. Leaking trunk and heat. I'm not concerned with the heat that radiates off the enging but my oil temp that at times is 300 degrees measured with a fairing mounted oil temp gauge. I am going to do a Stege 1 which should help take care of the heat issue. It will certainly not cure it. The MOCO needs to get their act together and remedy the leaking trunk. I can live with that until they fix it but I will not wait forever.
Old Jun 29, 2009 | 12:49 PM
robandlyn's Avatar
robandlyn
Holy crap !
Where is your heat sensor located ? Bottom oil pan plug ?
We are using the LED oil filler temp gauge but we also have one in the fairing
where the air temp was. That one measures the oil temp comming out of the
HD premium oil cooler (like what is on the Tri Glide). The hottest I have ever
seen was 245 degrees but since we did PC3, pipes and high flow A/C the temps
have only gotten to 220 degrees. Remember these are on our 07 Ultra & SG.
Have you thought of doing the Fuel Moto setup or are you concerned about
the warranty being voided if you did do it ?
Rob ....
Old Jun 29, 2009 | 04:43 PM
TheJimer's Avatar
TheJimer
Oldmsocko,
Unfortunately (IMHO) there isn’t a single answer solution to the heat problem; it is going to take a combination of several things to cool down the 103! And the “DEGREE” (pun intended) of the problem will vary from different parts of the country depending upon the ambient OAT.
Jim
Old Jun 29, 2009 | 07:18 PM
oldmsocko's Avatar
oldmsocko
Originally Posted by robandlyn
Holy crap !
Rob ....
Rob: The sensor is mounted in the oil pan. I just recently purchased the SE Air Cleaner so I will be having the stage 1 done to it. Once that is done I will see where my oil temp is and go from there. I do have a concern about the warranty.
Old Jun 30, 2009 | 07:49 PM
robandlyn's Avatar
robandlyn
You doing just the download or one of the HD EFI units ?
Rob .....
Old Jul 1, 2009 | 05:01 AM
oldmsocko's Avatar
oldmsocko
Rob .....
I'm just doing the download. I plan on putting a fuel management system on at a later date but in will not be the SERT. I was informed if I put anything on other than the HD unit I will void my warranty.
PopDukes
Mar 25, 2010 07:19 PM
TheJimer
20
Jun 8, 2009 10:31 AM
TheJimer
May 31, 2009 01:12 PM
TheJimer
May 26, 2009 10:33 AM
johnica
Mar 3, 2008 10:30 AM
