Oil Leakage thru Air Filter
I rather tend to think the overfill issue (draining some out) eases pressure within the system and that could be why it helps. If there is a positive pressure in the oil tank...it's just that much harder for the scavenge side of the pump to push the oil back in the tank. Usually, an overfill will result in a dipstick blow out, but you new guys have the screw-in dipstick.
That must be why letting a few ounces out tends to help. I am just making the point here that some people think you are pouring oil right down into the motor when you fill the tank...like in your automobile, but you're not. These are dry-sump engines.
I think the reason why is starts showing up after a few thousand miles all at once in some cases is....as the filter gets dirty it becomes harder for the intake to find it's air, resulting in more suction being applied to anything it can find...which is the oil vapor from the crankcase vent...which makes the filer more clogged and it just gets worse until you clean the filer and start all over again.
I'm not doubting your word or advice. I say....whatever works...do it!
The air filters are brand new (1000 miles) and not dirty. The vents on the CC are all in working order. The CVO 110 uses the same oil pump from model to model, same year. Fresh oil will not increase interior pressure but will increase oil pump pressure like the difference between cold and warm oil.
Both cases of the 1K aftermath resulted in oil dripping from the AC where it was not before. Also in both cases I rode the bike home resulting is a greasy mess and oil stained jeans... ughhhhh. Cleaning the Buffalo saddle bags on the ConV wasn't much fun either. Cleaning the hard bags on the SESG was a breeze but paint was damaged (long story). I removed both AC's and cleaned them out. Also found was oil standing in the neck of the TB.
In both cases our plugs were not removed and checked. How do I know? I loosened both rear plugs a little and tightened the fronts with anti-seize. Yes, I am a sneaky devil but you already know that.
Oil just doesn't "blow out" by itself. There has to be a mechanical reason. A clinical test was set by my experience after a baseline was established. In both cases the reduction of oil quantity was reduced (draining) and no further blow out was noted. One could only gather the decrease in interior volumetrics produced by lack of ventable air (compressible) replaced by the increase of oil (non compressible) and out comes the puke (so to speak). The only question that remains is, will 1/2 qt of oil actually replace the same volume of ventable air in the crankcase and cause said oil to push be means of vapor or liquid through the head vents and cause cold engine blow-by?
Isn't that why a PRV was invented? In most internal combustion engines you maintain pressure within the engine crankcase below atmospheric. This reduces leaks through gaskets and seals from the crankcase. This also reduces the risk of horsepower reduction by driving the unnecessary air pump created by piston movement. The crankcase vacuum shouldn't be too excessive, which would cause outside air to be pulled through any worn crankcase seals or gaskets. PRV's maintain a slight crankcase vacuum and maintain a negative vacuum, right?
A "Blow off valve" would eliminate the slight leanness created with the pressure increase in the air box while under braking. This device will blow off the excess pressure if you had one but... since we don't it's pushed to the AC taking the oil with it. I think they call that "power venting".
Thanks VT.. now you got me hitting another pot of coffee this morning.
Sorry to get off track Barb... VT and I are just like this sometimes. Since he is getting old I help him keep his cobwebs cleared.. LOL
I was already on my second pot of coffee this morning....what do you think started all this!
Is there a machine that can be plugged into the trike and isolate a problem? Like in cars?
Writing and printing out responses....wish me luck. Hope they don't push my "jack-***" button
This is not an isolated issue. Barb... I would run the bike and if it pukes oil again have them simply remove 1/2 qt of oil. It will not hurt your trike and you are running good temps. I would have also told him to take his bill and put it where the sun doesn't shine... he already said it was too full.. that was there problem, not yours to pay to fix.
Mgr said just ride it.....also, I wasn't charged, that's the amount that he has to keep track of for warranty work (whew)!! Got me 7 yr extended warranty.
Of course, now there's rain in the forecast for the next week.
