1997 Heritage
Old Oct 30, 2014 | 03:03 PM
Heritage1997's Avatar
Heritage1997
Stage I
Default 1997 Heritage
Hey, I just bought a 1997 Heritage with 540 miles on it and it has been sitting for several years. I changed the fluids and cleaned the gas and replaced the plugs. Also removed the bowl and cleaned. The bike starts with the choke out but if you give it any gas or push the choke it at all it dies. Any ideas?? thanks for your help..
Old Oct 30, 2014 | 03:16 PM
UltraNutZ's Avatar
UltraNutZ
fuel lines? sitting up that long I would think they would all need to be replaced for piece of mind anyways.
Old Oct 31, 2014 | 06:25 AM
grbrown's Avatar
grbrown
Wink
I suggest you remove the carb and thoroughly clean it, also replace the idle jet, which is probably blocked. You can get a service kit with most if not all the parts you need. Check one of the on-line parts websites, like this one, for part numbers. You can try to clean jets, or save yourself a lot of messing around and replace them for just a few bucks each!
Mjc5492
Jun 9, 2015 01:59 AM
CptRednutz
General Topics/Tech Tips
Jul 15, 2014 01:56 PM
katn0
Exhaust System Topics
Jan 31, 2011 08:54 AM
craun2
May 11, 2010 09:44 AM
rkthd89heritage
Aug 11, 2008 03:23 PM
