A little Help? - Error Code 21 left output failure
Old Apr 24, 2007 | 12:43 AM
WdGldDave's Avatar
WdGldDave
Default A little Help? - Error Code 21 left output failure
OK, I installed a new headlight on my 01 wideglide. Everything was great for several months. Recently I wanted to clean up the front by adding some chrome bolts and covers in place of the stock riser bolts. When I made the change, I capped off the ground wire coming off of the Cobra II headlight that I had previously added. The vendor told me the light would ground itself and didn't need to be wired. Things were fine for a while. Eventually my key indicator light started coming on from time to time. Long story short - now my left turn signal doesn't work. I hooked the grounding cable back up but still have no turn signal. I used TC's directions to check error codes and the code = 21 left output failure. Where do I go from here? I did try to erase the code but the left turn signal still doesn't work. I checked the bulbs already. Any advice will be greatly appreciated.
Andrewnc
Jun 27, 2018 07:50 AM
Cozz
May 7, 2018 11:31 AM
ddg22
Electrical/Lighting/Alarm
Jan 1, 2016 10:25 AM
trainwreak
Aug 10, 2009 04:52 PM
WdGldDave
Apr 28, 2007 05:40 PM
