freaking out
Old Jul 12, 2015 | 09:46 PM
brad594's Avatar
brad594
Default freaking out
99 Road King with a M/M EFI. New: ECM, crank sensor, Cam sensor; no security, all instruments work, fuel pump pressurizes then after 3 sec, it quits and also the coil receives signal, 12v, then looses it after 3 sec ??? Does not start....any help out there?
Old Jul 15, 2015 | 10:03 PM
Ed Ramberger's Avatar
Ed Ramberger
You just described normal operation. That circuit will not turn back on until it sees a crank signal. The EFI system powers up at key on then the relay is turned off until the ECM sees a crank signal.
What other tests have you performed? Are there any codes? Did you check all fuses?
Old Jul 16, 2015 | 08:33 AM
larsfum's Avatar
larsfum
As stated before, Check for any stored error codes. Have the battery load tested. Resynch the IAC with the ECM.
imbuhlman
Nov 24, 2016 04:40 PM
onaride63
Nov 26, 2010 06:23 PM
Inyers
Nov 15, 2009 02:38 PM
dlwilson72
Jun 10, 2009 07:50 PM
mroadking
Sep 14, 2006 10:25 AM
