Headlight Fuse Blows
Old May 15, 2007 | 11:59 PM
Retired_Ted's Avatar
Retired_Ted
Default Headlight Fuse Blows
Looks like I'll have to start looking for a dead short - headlight fuse blows immediately as I turn on the ignition switch. Suspect a wire under the tank (since I just filled it - LOL).
Old May 16, 2007 | 02:07 AM
wesd41's Avatar
wesd41
Default RE: Headlight Fuse Blows
I had just the opposite problem a couple of weeks ago. If I turned my bars all the way to the left, my headlight went out. Traced it to the headlight power wire in the harness just ahead of the clamp aft of the steering neck. The wire broke clean inside the insulation.
Good luck with your search.
Old May 17, 2007 | 07:42 PM
pnw05ss's Avatar
pnw05ss
I had the same problem on my '04 FXDI. It turned out to be a bad low beam in the bulb. The hi would work, but low would blow. Try removing the bulb connector and turn on the ignition to see if it still blows the fuse. If it doesn't, then the problem is the bulb. Also, try a 20amp fuse in place of the 15a. If the fuse does blow w/o the bulb, its probably in your wiring. Could also be in the tail section.
Old May 22, 2007 | 06:58 AM
CLL375's Avatar
CLL375
I had the same problem.The headlight wiring wasgetting smashed between the triple trees and the neck. I looked at the wires and found they were exposed and touching...instant short. Hope that helps.
jamess71
May 18, 2023 01:27 PM
AtticusFinch
Sep 11, 2013 07:15 PM
crawly
Jul 26, 2012 02:41 PM
Big Twi$t
Jun 28, 2012 03:54 PM
55chevy
Nov 15, 2011 10:55 PM
