O2 eliminators
Old Apr 26, 2016 | 03:38 PM
Thet's Avatar
Thet
Default O2 eliminators
I've got a PCV and Autotune, but I bought the PCV used and didn't get o2 eliminators with them.
I'm going to build a set myself, but I'm having trouble finding info on what resistance resistors to use... I've seen 330 Ohm, 900 Ohm, and 1M ohm resistors... Which is right???
Thanks!
2008 Fatboy
Old Apr 26, 2016 | 05:42 PM
whittlebeast's Avatar
whittlebeast
1 meg should be fine.
Old Apr 26, 2016 | 07:31 PM
qtrracer's Avatar
qtrracer
You have to run the supplied o2 sensors with autotune. Not sure why you'd need eliminators.
Old Apr 26, 2016 | 07:34 PM
hrdtail78's Avatar
hrdtail78
The 5 doesn't need them. Only the 3 does. Are you getting a code?
Old Apr 27, 2016 | 12:50 PM
Thet's Avatar
Thet
The 5 has instructions to install the o2 eliminators for the stock sensors. I have the Autotune as well, with the 18mm sensors. I haven't started it yet.
Brunster11
Mar 29, 2015 11:17 AM
Clipper
Fuel Moto / Jackpot Mufflers
Sep 26, 2012 02:08 PM
cursedspirit
Apr 16, 2012 06:12 PM
scotracy
Mar 9, 2012 12:36 PM
Rubbit
Mar 21, 2009 02:36 PM
