check valve install problem
Old Oct 2, 2016 | 10:35 PM
richard 02's Avatar
richard 02
Default check valve install problem
Hi and well I and just about done installing my new check valve on my 02 softail deuce and of course the last thing is giving me a hard time. There is a plastic hose that attaches the valve to another fitting in the gas tank and it will not go on. The old one came off with a good tug but I don't want to really force the new one on as the fitting is plastic and If I break it more problems. Is there a trick to this? I tried oil and helped a bit but will only go on maybe 1/8. Thanks
Old Oct 3, 2016 | 07:56 PM
Ed Ramberger's Avatar
Ed Ramberger
You really have to push it on. It will pop over the ridge and seat. Then clamp it. I use a little grease or lube.
Old Oct 3, 2016 | 10:00 PM
richard 02's Avatar
richard 02
Woot Woot I got it on. What I did was used the heat from a work light and heated the plastic up really good and pushed it on clamped it up and I am good to go. All back together now and took a quick ride and no gas leak.
richard 02
16
Oct 25, 2022 03:54 AM
Grizzwood
Oct 22, 2020 01:06 PM
Chrisannagenna
EVO
11
Oct 9, 2018 11:37 PM
conjurski
Jul 8, 2013 12:04 PM
Pog Mo Thoin
Jan 21, 2011 07:50 AM
