Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Because the 2007 models have the 103" flywheel set (stroker) which requires different timing than the stroke that was in the 99 - 06's. With the stroke, the piston speeds and timing requirements are quite different.
Did you dyno that Nightrain build? I am doing something very similar to my FXSTC this summer, so I am curious where that build landed you on the HP scales.
