SERT Map Help?
2005 Softail Deluxe
bored out 95cu in
256 woods cams (gear drive)
270-290 ported and polished high flow heads.
Screamin Eagle 50mm throttlesbody with K&N filter
Hooker step tuned 2-2 long pipes.
11-1 compression
I realize i am gonna loose a little out of the hole with the cam, or down low torque, but my body can't take the high G-force any way. With this set up i should really be hitting good power at about 2500RPM close on either side to what i cruise at.
the harley certified mechanic I'm using has little race tuner experience but is of coourse very familiar with the mechanical terms it contains. But still, this is a bit of a learning experience for he and i so any help or advice would be greatly appreciated. As the local Harley dealer has even less knowledge of the SERT. In fact I am told that they do not even have a harley trained mechanic onsite. ANd I happen to know they don't have Dyno machine.
