TTS Tuning Help
Old Mar 26, 2018 | 12:24 PM
ptbjork's Avatar
ptbjork
Default TTS Tuning Help
Looking for some tuning advice for my 2003 Road King with Delphi. Purchased bike last year with HD stage 1 filter, slip-ons and a stage 1 flash. As expected dealer flash was very lean. Just finished the hydraulic tensioner upgrade with 37N cams advanced 4 degrees. The plan was to have some headwork done but will ride this year as is and most likely do big bore/ heads next winter. I purchased a TTS (blue) from member here and flashed the recommended map. Bike runs very good. Idle, off idle and acceleration I am very happy with. Looking for some tuning advice. I am unable to use the cam tune/ selector and not having 02 sensors, where would you guys start? Or ride as is? So much information out there, but a little confused. Thanks.
Old Mar 26, 2018 | 07:47 PM
jbarr1's Avatar
jbarr1
If it runs good, what’s the issue? You could find a competent dyno tuner to evaluate the current tune if you’re concerned.
Old Mar 27, 2018 | 05:17 PM
ptbjork's Avatar
ptbjork
Just was curious what others would do. Never messed with a EFI bike and or tuner before. Thanks.
sjbodie
13
May 30, 2022 12:47 PM
dajogejr
Jul 27, 2016 10:27 AM
605bob
Aug 28, 2014 08:35 PM
user 78082023840
Mar 29, 2013 10:29 AM
cbennett
Jun 1, 2009 05:54 PM
