Throttle -Slow return
I am having a difficult time with my 2018 Road King throttle. I wish it had more tension to spring back .It is too sensitive at least for me. I am aware more tension may cause hand issues while riding. Small tight spots slow speed it is constantly revving when I just touch it.
Any ideas would be helpful. Wish it was cable drive I would fix it myself.
Mikey
Mikey
Throttle.
Thank You very much for your reply. I am looking to increase the tension. I want the throttle to be more difficult to rotate. When I am in my garage manuevering the Bike my right had has more than once raised the RPM
without wanting to do so.
I would like you to know I am a mechanic but do not know about this electroniic Throttle.
I am just looking to operate safely. I appreciate your help.
Thank you..The more I read the more complcated this electronic throttle is. A short read just stated that there is a return spring inside this device as you said..
https://ridermagazine.com/2009/02/12...ottle-control/
Yes you are correct.
While cruising a throttle with a heavy pull back return spring will cause hand fatigue.I am just going to have to learn how to manipulate the bike using my left hand to turn the front wheel.
It is so sensitive and I am so low on experience it has caused an issue multiple times.
Thanks for the sensible response.I appreciate it.....
Mike........
Mike........
If you have a tuner, you can set throttle progressivity to make the throttle less sensitive at lower positions. Another thing you can do is learn to use the friction zone on the clutch. Keep the Rs at say 2000 rpm and use the clutch to move the bike.
One of the problems with the M8 is that the friction zone is too narrow and the clutch engages too far out. There is a spacer you change in the clutch to widen the friction zone and bring the lever in a little. HD made the change in the 2019 bikes.
hasten21
06-17-2013 08:40 PM
