Tuning issues
Old Aug 1, 2019 | 04:42 AM
blackjeep's Avatar
blackjeep
Update
already had cam chest open to check cam timing when “sump check” was suggested so just kept going.
Cam timing was perfect.
Scavenge o ring was not... wasn’t pinched but was definitely loose fit with pump. Installed new one and was a nice tight fit sliding pump back on. Got a feeling you guys nailed it. Pushrods and pipe go back on tonight with test ride to follow.
Thank you so much for help guys!!!
Old Aug 1, 2019 | 07:10 AM
marcodarq's Avatar
marcodarq
Just remember that if it was sumping and you have not drained the crankcase, it might take a few minutes of enginee run time for the pump to clear out the excess oil. Let it idle till its warm , then light throttle application for a bit and listen to it, as you ride, then see how it acts.
M
Old Aug 1, 2019 | 07:41 AM
blackjeep's Avatar
blackjeep
Looking forward to test ride!
Old Aug 1, 2019 | 05:11 PM
blackjeep's Avatar
blackjeep
Fired her up after assembly. No ride yet. Warmed it up and drained oil for a change and I don’t have a filter. Damn
seemed to rev quicker. Im optimistic!
will get filter tomorrow and load her with fresh oil and post results after ride.
Again, can’t thank you guys enough for suggestions!
beers are on me if either of you cross my path!
Old Aug 1, 2019 | 05:15 PM
marcodarq's Avatar
marcodarq
because you have no location listed in the upper right corner, who knows if we'll cross paths???? where are you located in general?
m
Old Aug 1, 2019 | 07:51 PM
blackjeep's Avatar
blackjeep
Woodstock Ontario, Canada.
Old Aug 1, 2019 | 08:12 PM
marcodarq's Avatar
marcodarq
well considering that i'm way deep in south florida, it's not likely that we'll cross paths, but i still wish you luck with the current endeavor!
m
Old Aug 2, 2019 | 01:51 PM
blackjeep's Avatar
blackjeep
Update. New scavenge o ring. Re-set cam timing. All buttoned up and test rode. Smoother and a TON more power. Even ran cooler.
Feel dumber than a pile of rocks that I didn’t catch this but I’ve got a whole new motor. Can’t wait to get it back on dyno!
im 300lbs and pulling away from a stop if i crack to wide open throttle (once clutch is fully out) it will spin the crap out of the wheel and when i switch to second it keeps blacktracking the tire for about 30 feet.
Couldn't be more happy. Thanks for all the help.
After dyno i will post results.
Old Aug 2, 2019 | 02:36 PM
marcodarq's Avatar
marcodarq
I've been working on bikes for 35 years more pro than not, and TC's since they came out, and of all the bikes that i've worked on, the one where i made this error was my own bike!!
glad to hear that you got it worked out and anxious to see the dyno results, good job!!
marco
Old Aug 7, 2019 | 07:14 PM
blackjeep's Avatar
blackjeep
Well. Tuning done. Bike runs amazing!
made 97hp and 113lb/ft
broke 100 lb/ft at 3000rpm and gradual climb to 6000rpm.
Roll-ons on highway put a grin on my face everytime!
thanks to you guys for figuring out sumping issue!!!
