Won’t start !!
Old Feb 17, 2020 | 01:15 PM
Jay Guild's Avatar
Jay Guild
Also, don't listen to that fool that told you to throw away a $800 ECM with wide band O2 sensors. It's the only tuning system with wideband sensors and no piggyback pieces.
Old Feb 17, 2020 | 08:28 PM
Jordan Stephens's Avatar
Jordan Stephens
Stage IV
I would never throw it away lol I’ve already connected it to my pc with a thunder max tech on the phone and he said to send it in .. that’s only way he can tell if something is wrong with it .. FYI brake cleaner is flammable so anything like that would start the bike .. what should compression be I can test it tommorow
Old Feb 17, 2020 | 08:43 PM
Rick17FLH's Avatar
Rick17FLH
Anything over 90 psi is considered acceptable, 145 - 165 psi is considered excellent for a stock motor. The cylinders should not differ by more than 10%.
Old Feb 17, 2020 | 10:17 PM
Screamin beagle's Avatar
Screamin beagle
A guy that works for a machine shop.that we do business with bought an 07 street glide from an auction. He was trying to get it started and one day he had stopped in to pick up some stuff we had made for them. We start talking bikes and he tells what he got and that he did a compression test and had 20 on one cylinder and 12 on the other...definitely not good. Told him sounded like bent valves, bad lifters ,no oil...just told him it could be a any number of things. I said you won't know until you start taking it apart. He pulls the pushrod tubes and no pushrods. Then he pulls the cam cover...no cam plate, no cams, no pump ...nothing empty like a blonde polish girls head. It was a repo so the p.o. must have had cams and nice pump and plate in it so he pulled it before it got repo'd. He replaced all that and I told him that he might want to pull the primary cover...derby cover at the very least...gotta change fluids before you even start it I told him. Luckily that side was still intact. But just goes to show what some people will do.
00copglide
Sep 1, 2019 02:07 PM
En3may
Shovelhead
May 28, 2012 03:06 PM
DFX
Welcome Area Only
21
Feb 7, 2009 03:42 AM
Crank
Exhaust System Topics
Nov 29, 2007 09:05 PM
orfin
Sep 29, 2007 12:31 AM
