Error code P1505
Old May 23, 2020 | 01:44 PM
jacka1's Avatar
jacka1
6th Gear
Default Error code P1505
Hi all,
I've a 2020 1200 sportster. I recently installed V&H mini grenades, and an arlen ness big sucker (little lockdown project). Install all good, everything tight, no leaks as far as I can tell. FP3 mini grenade map flashed onto ECM.
First ride out, running lovely. Once warm, I take it just over 4000rpm, all of a sudden it sounds like I've hit a rev limiter, engine light comes on and revs now won't go over 3000? I get it home and use the FP3 to find the p1505 fault code (power limit violation). I cleared the code, and reinstalled map just to be sure. Taken it out again today, same thing has happened again.
Does anyone have any ideas? Everything running so good till this point!
Thanks in advance.
Old May 23, 2020 | 02:06 PM
marcodarq's Avatar
marcodarq
are you flashing a map for an HDI model bike. HDI = Harley Davidson International
m
Old May 23, 2020 | 02:28 PM
jacka1's Avatar
jacka1
6th Gear
m
Yes, bike purchased in England.
Old May 23, 2020 | 08:17 PM
Ed Ramberger's Avatar
Ed Ramberger
They program rev limiters into Street models used in rider training. I haven't heard of it in other models though. When the ridder exceeds the preset rpm in a gear it is a rev limiter and states Power Limit Violation.
My initial thought would be to check the rev limit set in the map.
Old May 24, 2020 | 03:02 AM
jacka1's Avatar
jacka1
6th Gear
Rev limit is set to 6200rpm on the FP3.
I thought about this but when I had stock exhaust and map it wasn't an issue.
Old May 24, 2020 | 10:33 AM
jacka1's Avatar
jacka1
6th Gear
Update- I cleared the code, took it out for a ride and happened again after a few times of hitting 4000rpm.
I’ve checked for exhaust leaks and can’t find any. Could this be happening due to a bad installation by me? Everything looks fine and running fine.
Old May 31, 2020 | 01:15 AM
Max Headflow's Avatar
Max Headflow
Miles on the bike? Maybe it's a break in thing.
Old May 31, 2020 | 02:30 PM
jacka1's Avatar
jacka1
6th Gear
Coming up to 1000 miles. Would Harley put this on though? Only way to clear the code/limit/engine light is to plug it in. If someone didn't have an FP3 or similar, that's a lot of trips to the dealership
Old May 31, 2020 | 03:04 PM
Max Headflow
To protect the motor during brake-in? I seem to remember someone mentioning this on international HDs. You can probably clear the codes through the speedo but am both sure.
I can see some guy going into a dealership and saying, "I'm not obeying break-in rules, can you clear the code for me?"
Old May 31, 2020 | 03:24 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Hi all,
Thanks in advance.
Sounds like the FP3 has put the wrong calibration into your bike. There are different regulations in Europe than the USA. The P1505 is letting you know that you've exceed the limits and shuts the power down to a new fix RPM limit.
