2003 flhr code 99
Old Jul 30, 2020 | 06:28 PM
WraithReaver's Avatar
WraithReaver
Default 2003 flhr code 99
I have a 2003 Road King w/carb that I was trying to retrieve the trouble code(s) for the breaker popping after 2-3 miles of riding, to see if it's the crank position censor, one of the coils or whatever, but I get code-99 "Incorrect/Missing Password." I don't have a Harley key fob and the security is Digital Guard Dog, not a new one but a 2003 model. I'm the 2nd owner and the 1st is no longer around, so Idk if it had Harley security at one time but there is a 15amp fuse in the "security" slot in fuse block. Is there any means to bypass needing a password? I know the procedure for newer bikes using the odometer because every search brings up that and how to retrieve my codes...but nothing on what happens for code-99. Is a dealer the only option?
Old Jul 31, 2020 | 07:08 PM
Max Headflow's Avatar
Max Headflow
Don't know how to retrieve codes but if the breaker is popping at 2-3 miles, you probably need to replace it and clean up the crimp terminals going to it.. Resistance in the crimps overheat the breaker. Crank sensor or coils can't blow the main breaker.
duaneduanet
Apr 2, 2020 08:39 AM
hdfxdwg2001
Jan 29, 2014 07:24 AM
jacksonfdny
Oct 31, 2012 11:08 AM
RK1
Apr 19, 2011 07:26 PM
OhioSkully
Oct 31, 2009 12:42 PM
