Screaming Eagle Tuner
Old Aug 14, 2020 | 02:22 PM
Jhcarden's Avatar
Jhcarden
Originally Posted by todd-67
^^ is your answer. The only time that the SE tuner mandate is in place is on 2017's and later models. An aftermarket tuner would only be discoverable by Corp if they plugged it in. If you are on an extended warranty not the 24 month factory warranty, The ESP isn't going to require that disclosure nor can they get it without going through the MoCo unless they have expanded the dealers ability to do so in the very recent past.
The SE tuner may or may not work with your combo as it is very restrictive on what can be changed and by how much. The other tuners do not have these constraints and will yield a much better performing bike.
I’ll call the warranty guy back and ask if a TTS or power vision will be ok. Pretty sure he said no and my only option was screamin eagle. It was a used bike so I have some sort of after market warranty.
Old Aug 14, 2020 | 03:43 PM
Jay Guild's Avatar
Jay Guild
Originally Posted by Jhcarden
So I think I figured out my problem. The screamin eagle tuner will work with Vance and Hines 2 into 2 big radius with stock baffles. But once I put the more open big city thunder there is less back pressure and the screamin eagle tuner can’t handle it. I would have to go with a FP3 or something to run the big city thunder baffles. I will find out today if putting the stock baffles back in fixes the issue. Once I find out I’ll update.
So which baffles were in when they supposedly tuned it? Aside from that, it's not that the tuner can't handle it, the MAP is not appropriate for your VE and you are getting more reversion due to lower exhaust speed. Depending on which tuner you have will determine how much you can tune it specific to your setup. If it only lets you load canned maps then look for something that is for long drag pipes or the like.
Old Aug 14, 2020 | 05:07 PM
marcodarq's Avatar
marcodarq
if your bike is out of HD factory warranty, you can run any tuner you'd like. aftermarket extended warranties don't care.
that being said, the Pro Street Tuner,,,(Street being the key word here) is not your est option and neither is an FP3 if you think you are going to do more upgrades in the future. do yourself a favor, do it right and get a TTS or a powervision tune. The TTS is one of the most powerfull device/systems there is, the Powervision has a license program so that you dont need to buy the hardware if doing the actual work is not your deal, tuning takes a lot of knowledge and equipment and practice. for some its best left to a pro, set it and forget it.
m
Old Aug 14, 2020 | 05:42 PM
Jhcarden's Avatar
Jhcarden
m
yeah I may go down that path one day. I’ll check with the warranty guy and see if a TTS tuner voids my warranty. For now the bike is finally running great. Took the big city thunder baffles out and out the big radius baffles back in. Bike runs perfect and still sounds awesome. For now I’m just going to enjoy the bike. I’ll hang on to the big city thunder baffles for the future when I decide I want to get a TTS tuner and put the baffles in.
The screamin eagle tuner will not work with big city thunder baffles. I had a very good tuner working on this bike. So I am confident in saying that.
Maybe someone will come on here and say it can be done. Would love to hear that.
Like I said, the bike runs and sounds great and I’m going to enjoy the hell out of it.
Old Aug 14, 2020 | 05:51 PM
Jhcarden's Avatar
Jhcarden
first go round I had big city thunder monster baffles in and using a screamin eagle pro street tuner. It just didn’t work. If I want to run BCT baffles I’ll have to go with a TTS or similar.
Old Aug 14, 2020 | 11:17 PM
Jay Guild's Avatar
Jay Guild
If you can't find a canned map that the sepst will work for the baffle then yes. You would need a tuner that provides more resolution for tuning. The shop though only did a program and ran one run on the Dyno, if they did a Dyno at all. That tuner can't adjust the maps with enough resolution to be able to rune multiple Dyno runs to adjust the maps for any particular set-up.
Old Aug 15, 2020 | 12:09 PM
Jhcarden's Avatar
Jhcarden
yeah that’s what I figured out. I’m new to all of this so I’ve been doing lots of research. I need to call the warranty guy back and see what tuners other than screamin eagle I can use that might allow me to go back to my BCT baffles.
Old Aug 15, 2020 | 01:33 PM
60Gunner's Avatar
60Gunner
curious on this statement. I had thought that harley rendered them useless with the software updates that they came out with after the concent decree. Interested if anyone can verify it one way or the other.
This is bs. I have the SE Pro Super Tuner (orange) 32109-08C that you can't buy anymore but my bike being a 2013 had it before Harley was fined and forced to quit selling it. It just as capable as the tts or powervision. Maybe not as user friendly, but just as good.
Old Aug 17, 2020 | 05:53 PM
FLTRI17's Avatar
FLTRI17
If you look at the advertised capabilities of these products (tools) you must conclude they are all more than capable and offer the same features and tuning aids.
IMO a good tuning tool must be easy to understand and use to be successful tuning an engine to its potential of smoothness, throttle response, overall power, as well as good fuel mileage.
As a tuner, based on ease of tool use and end it’s ending tune quality.
I list below my personal preference.
1) TTS Mastertune (Great 100% functional tool offering a few unique tuning aids and features that makes a difference, backed with excellent, responsive tech support from
2) Screamin’ Eagle Pro Supertuner (Gets the job adequately but without any tech or product support whatsoever)
3) Power Vision* (Having to deal with the postage stamp size monitor is a PITA, some features don’t work as advertised, limited tech support at best from Dynojet) Thanks goes to Jamie for supporting the product 👍
Bob
Old Aug 18, 2020 | 07:46 PM
Jhcarden's Avatar
Jhcarden
Bob
the only issue with the screaming eagle pro street tuner is that it cant handle open pipes or baffles like the BCT baffles. It has to many limitations imposed by the EPA, and if I don’t use it and go with aftermarket my warranty is gone. So unless the guys at the local HD are just crap tuners, which I don’t think they are, I’m stuck with the pro street until my warranty expires or I just say **** it. But in my mind, getting a little bit louder vs warranty is an easy decision. My bike still sounds great as is.
