PowerVision gauge display problems
Old Aug 23, 2020 | 12:20 PM
Eddie Wolf's Avatar
Eddie Wolf
Default PowerVision gauge display problems
2019 FXLR, tuned with PowerVision...
8K on the clock and 1 year installed.
Have one window setup for fuel economy.
MPG, fuel used, miles traveled...
Worked ok up until now... after resetting trip a or b, it runs up to .2 miles and just stops registering.
All the other windowed setups work just fine.
Am I missing something here?
Old Aug 25, 2020 | 05:57 PM
jackddg22's Avatar
jackddg22
I have a 2017 Low Rider, have not been able to get mileage
to work, trip logger will track fuel used, but not miles traveled.Speedometer matches bike speedometer.
Any ideas?
​​​​​​​Thanks, Jack
Old Aug 26, 2020 | 07:43 PM
2017M8's Avatar
2017M8
Send DynoJet a quick note off their website,,,There maybe a firmware / software...
Old Aug 27, 2020 | 06:11 PM
jackddg22's Avatar
jackddg22
Fixed it, went to the trip window and it was showing 0 miles traveled. I have a loop I run that's 18.6 miles. I inserted 18.6 miles correction and reran the loop. It showed 22.9 miles traveled. I entered 37.2 (18.6*2) .I will have to do this a ew more times to get it to read correctly, for the fuel used gust guessed as close as I could
Old Sep 17, 2020 | 06:06 PM
Eddie Wolf's Avatar
Eddie Wolf
After spending a week or so with the great folks at DynoJet, have it working again...
Ended up doing a complete restore of the unit, and after that everything works again.
Old Sep 18, 2020 | 07:43 AM
smitty901's Avatar
smitty901
Fuel economy and MPG display on Dynojet has never been even close. Everything else works fine.
Old Sep 18, 2020 | 07:45 AM
Eddie Wolf's Avatar
Eddie Wolf
There is a setting for adjustment for that. Adjusts the fuel taken vs the fuel used...
Old Sep 18, 2020 | 08:26 AM
jackddg22's Avatar
jackddg22
What is a complete restore and how did you do it??
Not for a friend, for me.
Jack
Old Sep 18, 2020 | 08:43 AM
Eddie Wolf's Avatar
Eddie Wolf
Jack
OK,
FIRST, open the Dynojet Power Vision WinPV on your computer.
plug the power vision unit into the usb on the computer.
WinPV menu... PowerVision, then Diagnostic / Test Functions then Get ECM Data (Diagnostic from PV.
small window opens, click Yes
Get + Delete all files (you have to highlight all of them), and save them to your computer.
there... after all that....
go here....
https://dynojet.zendesk.com/hc/en-us...pdate%20Client.
follow all the instructions carefully...
then after all that...
umplug the PV, close everything...
open the PV Update Client
plug the PV back into the computer...
1. update the firmware...
2. update the database.
If you did all that correctly it is done.
Geesh....
Old Sep 18, 2020 | 02:49 PM
smitty901's Avatar
smitty901
I will look into it. Tugging a twin sidecar fuel economy is not a big issue it burns more fuel. Once over 70 is where it really shows up. Just returned from a 4 day ride. Some of the riding we did was in traffic that was moving 80 +. So we were also I had turned the Power vision fuel gauge on just to see what it said . No new to PV just never really played with the fuel economy part of it.
