FP3 map with Fullsac
Old Oct 15, 2020 | 01:38 PM
JABMIKE's Avatar
JABMIKE
Default FP3 map with Fullsac
Any suggestions on a fp3 map for a stock 103(FLHTK) with decatted head pipe and Fullsac 2.0 baffles? Currently using V/H monster rounds map. Seems to run a little rough.
Old Oct 15, 2020 | 06:41 PM
MyFavRk's Avatar
MyFavRk
I started the same way you did , with the decatted stock header , never could get it to run right . Once you decat the head , the 02 sensors are so close together that it messes up the tune , at least that was my thought . Once I got a V&H header , it did run much better .
Try the Twin Slash Round , not the monster round . Send an email to V&H through the app's customer support and explain exactly what set up you have . Tell them what issues your having as well . Don't forget to send the bike's serial number along with it . At the same time upload that map to them . They will make the necessary changes and sent it back for you to flash .
Hope you get it runnin right !
Old Oct 15, 2020 | 08:54 PM
JABMIKE's Avatar
JABMIKE
I have been thinking the stock head pipe has been the problem. I have tried a couple different mufflers and none of them felt quite right. I might invest in a different head pipe.. Thanks
doug62
Audio Systems
May 27, 2024 09:00 AM
JZFloatingkent
The Dyno Room
May 16, 2017 12:50 AM
airjoe
Aug 5, 2016 09:45 PM
brutalbrad
Sep 15, 2012 12:55 PM
