Cannot get fire
Old Jul 28, 2007 | 07:59 PM
Cool roadking's Avatar
Cool roadking
Stage I
Default Cannot get fire
This morning my 2001 Roadking wouldn't start. Checked for fire. No fire @ the plugs. Checked the fuse box and everything was fine. I then checked the coil module. It was fine and I am getting 12 VDC to the center post to the module. Borrowed a test ignition module from the local bike shop and plugged it in. No luck, still no fire @ the plugs. Thinking that maybe it is the crankshaft position sensor I disconnected it and checked the resistance across it and found it to be 0.653 Meg. Ohms. I'm not sure if this is bad or good as neither the shop manual or the bike shop has this specified. Also, as I bought the bike used, I'm not sure if the security system has locked out the ignition system and do not have the pin numbers for it. Anyone have anyideas?
Old Jul 28, 2007 | 08:42 PM
vheflin's Avatar
vheflin
Default RE: Cannot get fire
I assume the plug wires checked out okay? No fire at both plugs makes me think the coil may be shot or a loose connection somewhere. Good luck.
Old Jul 29, 2007 | 05:44 PM
jmetro's Avatar
jmetro
sounds like the security system, it kills the ignition. might need a new tssm
Bcoish
EVO
11
Apr 29, 2019 09:09 PM
1988lowrider
EVO
11
Jun 1, 2018 03:31 PM
Mrukus
EVO
Jul 2, 2013 09:50 PM
meatball
Jun 28, 2006 11:50 PM
Freeroamin
Jun 27, 2006 03:58 PM
