Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
2009 flhtcu, I swapped my handlebars for TBars. Theres about 30 or so wires coming from the control housings so I did not internally wire the Tbars except for the throttle wires. Everything works just fine except for now the bike cranks but wont fire up. You can hear the fuel prime when you flip to run. Hit start and it just cranks. I ride this bike almost everyday, it was running great with no issues before I changed the bars. No pinched wires at the control housings. All the plugs are plugged in. I am stumped, I've gone over these wires and plugs for too long now. I need help, what am I missing?
Having removed wires from plugs have you mirror imaged them, reversing their orientation?
Have the pins been fully inserted in the housings, none backed out? Has a pin(s) got bent?
No codes showing and the plugs are in the exact places. The previous owner extended these wires so they have been spliced before. So I REspliced and shortened the wires. So the pins and plugs havent been messed with
Probably a wire.
If the wires in the throttle are screwed up, bike may not start. IIRC if the ECM thinks the throttle is wide open, it won't start the bike and not throw a code.
