Won’t start
Old Jul 23, 2021 | 09:19 AM
Jay Guild's Avatar
Jay Guild
Stop screwing around with jumper cables, if the battery is weak, find the problem.
You can`t troubleshoot an electrical issue until you know the battery is good, and load testing is the only way to know the condition of the battery.
Fully charge the battery, take it to an auto parts store and have it load tested.
Clean battery cable connection points.
Re install new or tested good fully charged battery.
Let us know the results.
And put some effort into composing your posts, your original post is indecipherable.
I think there's bigger problems to address first, like the fuel pump running for several minutes when turning the key to the ON position. F the battery, man. You got some shorts in your wiring or some sensors out that are draining the electrical. Sure you can test if you can continue to use the battery, but you'll just keep going through batteries until you fix the electrical issue.
Old Jul 23, 2021 | 06:45 PM
EVOrider's Avatar
EVOrider
That post is really hard to understand…..come back and re-post it. Try to be specific and use some sort of pronunciation.
That’s helluva long sentence!
The better you post a problem…..the better we can assist.
Old Jul 24, 2021 | 12:24 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I gave suggestions for simple steps to be taken.
You must have a good battery to begin.
And it wouldn`t kill the OP to post a clear description of the issue either.
Old Jul 29, 2021 | 08:49 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Looks like a one and done...
Old Jul 29, 2021 | 12:27 PM
Ed Ramberger's Avatar
Ed Ramberger
I've pretty much stopped answering first posts. A lot of them sure seem like
Old Jul 29, 2021 | 01:41 PM
eighteight's Avatar
eighteight
Originally Posted by EVOrider
. Try to be specific and use some sort of pronunciation..
Is that the same as punctuation ?
Old Aug 6, 2021 | 11:37 AM
Max Headflow's Avatar
Max Headflow
It's the key fob battery.. ;D
Old Aug 8, 2021 | 01:11 AM
FLTRI17's Avatar
FLTRI17
Battery
Mr.Lee
General Topics/Tech Tips
37
Jun 28, 2021 09:29 PM
321
Aug 18, 2017 10:46 AM
gwatson66
Exhaust System Topics
Jul 7, 2010 10:14 AM
GypsyRoseTattoo
Jun 26, 2009 09:36 AM
firefighter3666
Sep 21, 2008 08:02 PM
